Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 > Exhaust
Exhaust 4.7L Exhaust Discussion
United Radio
Old 11-26-2013, 08:51 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Will do, I'll probably post pictures sunday. I'll have some of my buddy's z28 as well, we are redoing his exhaust too. That's a pretty fun car.
Only thing I'm worried about is if my O2 non fouler trick will work. I've read alot of people have trouble with it on the 4th gens. Not sure what to do if it doesn't work, only other option I can thing of is custom tune but no way I'll give up the superchips. So prob just live with the light... Let's hope the non foulers work...
Sean
Old 11-26-2013, 10:54 PM
Hornet Hornet is online now
Vehicle: 2013 RCSB Ram
Rep:460
Awright,are you using mandrel bent tubing?
I've heard of the non-foulers,but just what exactly are they.
I've never seen a pic or even a discription of what they entail.
Back when i was playing with my supercharged Buick Regal,the trick was to splice a 100 ohm 1/4 watt resistor inline with the back O2 when you dumped the cat,letting a constant low voltage feed through the 02.
I'm not sure if these O2 sensors work the same though with the grounding circuit.
Old 11-26-2013, 11:11 PM
snrusnak's Avatar
Rep:1385
Yeah all 409 SS, mandrel bent. I am eliminating the cats, and instaling non foulers (see attached pic), and will have the whole exhaust be 6 pieces. dual pipes before the muffler in 4 pieces. The muffler (22" magnaflow dual 2.5" in, singel 3" out) another piece. And stock tailpipe the 6th piece. My current exhaust is nice but the collectors suck(as said above), I used aluminized pipe which is ok but he welds were mild steel, and I wish I made it in more pieces for easier removal/trans removal.
Sean
Old 11-27-2013, 01:08 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Or, you can do what I did and just get rid of the Y pipe and get a dual in/dual out muffler. Looks, sounds and works great!
Old 11-27-2013, 07:26 AM
Rep:460
Thanks Sean.
Looks like the idea is move the orginal sensor out farther so it runs cooler.
I'm assuming they work on a temperature differential if thats the case.
Could a guy plug the hole and attach the sensor right to the outside of the pipe.
I wonder if a guy could weld a stand-off reciever to the pipe and screw the sensor into it.
Rick
Old 11-27-2013, 08:04 AM
snrusnak's Avatar
Rep:1385
That's actually what I am doing, I'm replacing my y pipe with a dual in/single out muffler
Thanks Sean.
Rick
I'm pretty sure the way they work is they take a reading outside the pipe and inside the pipe and compare oxygen content (have no idea exactly HOW) and the way this trick works is by spacing the sensor out of the exhaust stream it somehow keeps it within it's range to not throw a code/CEL. Some people also pack steel wool in the spacers.
I've heard of the electronic resistor simulator trick too.
Supposedly computers are getting more difficult to "trick". So we'll see how it goes... It worked on my s10 like a charm though.
Sean
Old 11-27-2013, 01:22 PM
Rep:460
HMM,that's interesting.
If they're checking oxygen content they will be harder to fool.
I thought maybe they might work on a temp differential,but i gotta admit,i'm behind the times on these new ones,lol.
This is the first computor toy i've tinkered with since my old Regal,and it was 10 years ago since i was playing with it,things have changed somewhat since then
Do you know who's exhaust is that in the picture?
Somebody done a nice job on that system
Old 11-27-2013, 01:27 PM
snrusnak's Avatar
Rep:1385
The technology isn't getting newer, you're just getting older
Sean
Old 11-27-2013, 05:50 PM
Rep:460
LMAO,touche you got me on that one
Rick
Old 11-28-2013, 04:53 PM
Rep:460
Where are you guys getting the "spark plug non-foulers" from?
