Old 11-13-2013, 09:51 PM
Driver72 Driver72 is offline
Vehicle: 2014 Laramie CC 4x4 8spd 3.92
Color: White w/ Blk interior
Rep:69
Driver72 will become famous soon enough
There's only one muffler stock.... It's a single in, dual out which is what gives you your dual exhaust out the back.
Really?
I hadn't even looked, but I thought it was a true dual exhaust system?
2014 Ram 1500 Laramie CC 4x4 with LSD and 3.92's
2013 Ram 1500 Laramie CC 4x4 with LSD and 3.55's -GONE-
Old 11-13-2013, 10:56 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Originally Posted by Driver72 View Post
Really?
Nope. After the exhaust manifolds there's two cats. the drivers side pipe then runs underneath the transmission to a Y-pipe (a very poorly designed one) and into a single 3" pipe to the muffler. Then the muffler has dual 2.25" outlets to the back.
Old 11-14-2013, 12:02 AM
Rep:69
Well then, I'm betting there's quite a bit of power to be had by putting a true dual exhaust system on these trucks.
Old 11-14-2013, 02:52 AM
Rep:2026
There isn't going to be huge gains.... some people say a retaining a little back pressure actually helps with the low end torque. Not sure if you'd notice a difference or not though. Realistically swapping out the stock Y-pipe and muffler will free up about as much flow as you need unless you plan on supercharging the truck.
Old 11-14-2013, 09:42 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Driver72, you will lose bottom end response if purely stock. Especially if your MDS is active. That is the main reason for the "POORLY" designed y-pipe. 4cylinder backpressure. Now if you deactivate your MDS by way of ERS or a tuner, then yes, a free flowing, true dual you shall benefit from.
Old 11-16-2013, 10:02 AM
Rep:69
This is true, I forgot about the MDS.
And yes, backpressure definitely helps with lower end torque, but hurts higher end horsepower.
A perfect example is Mustang's 5.0 liter engine.
In the GT it makes 390 lbs ft of torque.
But in the Boss 302 which has a freer flowing exhaust, and intake manifold, which gave it 24 more hp on the top end, losses 10 lbs ft of torque.
But again, I forgot about the MDS, taking away a bit of low end torque will mean the MDS will not work as often and cut into fuel economy too.
But I'm sure there is a solid 10-15 hp in the mid to upper range of the rpm to be had....this is my first pick up truck so I still often think in performance car mindset and not low end torque which nice for a 5800 lbs truck too.
