Old 11-05-2013, 10:22 PM
LABIGHORN LABIGHORN is offline
Vehicle: 2010 bighorn
Trim Level: bighorn
LABIGHORN is on a distinguished road
Default Strange Led issue
Hello there all. Ive been lurking here and learning lots. I finally got back into a ram about a year ago after trading my beloved 2001 quad sport 4x4 for a Jeep. I did like the jeep but was never real happy. Any way I have been picking away at mods since i purchased the ram. Its a 2010 crew bighorn 4x4 hemi anyway i installed the led license plate lights about a week ago and they worked flawless until one off them now is on so dim that you can barely just make out the individual chips lighting tried cleaning contacts and reversing bulb to no avail my only assumption is the bulb is toast but I would assume it would simply would nolonger work at all in that case. Any ideas
Old 11-06-2013, 12:42 AM
RedSmart's Avatar
RedSmart RedSmart is offline
Rep:883
If you are getting some light out of the LED, then it could be as simple as a contact wire on the circuit board is not seated properly.
If you can open up the compartment where the LED's are mounted to the board and press on them, that could help solve your problem.
You can dim LED's if you have the proper driver and dimmer control, but that is usually reserved for the architectural or residential market and not the automotive.
How old is the system? Can you take it back to your point of purchase and get it replaced?
Old 11-06-2013, 01:13 AM
Trim Level: bighorn
There only a week old I can try and bring them back and see if he will reimberse me but electrical components can sometimes be a sticky subject
Old 11-06-2013, 01:18 PM
RedSmart's Avatar
Rep:883
So long as you didn't buy them from a flea market you should be okay.
Old 11-06-2013, 01:51 PM
Trim Level: bighorn
Haha no not a flea market but a little ma pop operation. They seemed very interested in my business they usually do home and car stereos and have branched into the vehicle accessory gig said anything I needed that they dont normally stock they would figure out a way to get it
Old 11-06-2013, 01:54 PM
Trim Level: bighorn
It was also mentioned on another forumn that 2010 s dont need canbus led lights for flicker etc so that makes it a cheaper easier game
