Old 11-05-2013, 06:43 PM
Bozo's Avatar
Bozo Bozo is offline
Vehicle: 2013 Ram
Trim Level: Laramie Crew Cab 4X4
Color: Copperhead Pearl
Rep:327
Bozo is a jewel in the roughBozo is a jewel in the roughBozo is a jewel in the roughBozo is a jewel in the rough
Default Towing and mpg questions
I have read through a lot of the threads here and it seems these questions appear together but I still would like some additional feedback.
I have an '09 1500 SLT 4X4 Crew, Hemi/5 sp auto, tow pkge, 20" chrome clads and 3.55 gears. I have a 6000 lb. dry weight bumper tow camper and I have never gotten the total weight on a trip but I usually tow with supplies and w/o water and waste.
My questions are:
A) is it normal to only get 7 or 8 mpg when towing in what I would consider mild foothills of SC, GA and NC? I tow about 55 to 60 mph even on interstates.
B) I found a used '12 3500 2 dr dually with the 6.7L turbo diesel and 6 sp auto., 17" wheels, limited slip and I don't know the gearing. Although this is most likely overkill for our camper, I was wondering if the mpg would be better with this combo vs. my '09 Hemi?
Normally I wouldn't look past a 2500 if I wanted to upgrade but a local dealer got this in on trade and it appears to be real nice. Plus, I don't know if we would ever upgrade to a larger, heavier camper.
I know my Hemi and 1500 can tow this current trailer OK, just curious about the fuel mileage on this 3500.
Any help and/or suggestions/recommendations would be greatly appreciated!!
Thanks!!!!
Tony
Cheap, Fast, Reliable; you can choose only two.....
Old 11-05-2013, 10:58 PM
Tippmannr Tippmannr is offline
Vehicle: 2010 Ram 1500
Tippmannr is on a distinguished road
My Hemi gets about 9MPG with my 26' enclosed that weighs about 4000lbs. A diesel would get better mileage towing, especially in the hills, plus you will have a lot more torque. My dad gets about 15MPG with the same enclosed under the same conditions with his duramax.
Old 11-05-2013, 11:12 PM
darkstar darkstar is offline
Vehicle: 2013 4x4 express hemi
Trim Level: express
Rep:80
darkstar will become famous soon enough
you would prob get near 2x the milage on the 2500 cummins truck
2013 express RCSB 4x4, 2.5in front, 1in rear lift, AFe stg 2 intake, magnaflow exhaust, Diablo tuned
Old 11-06-2013, 02:33 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
The Cummins will definitely get better mileage than your Hemi. If deleted it will probably twice as good. And it will pull your trailer like it's not even there. But it is definitely overkill for that size of trailer, especially a dually. The torque of a Cummins is amazing for pulling though. You definitely wouldn't be disappointed in that. So it's really up to you if you want to spend the money to get a nice upgrade but it definitely isn't necessary.
Old 11-06-2013, 03:34 AM
ajd76's Avatar
ajd76 ajd76 is offline
Vehicle: 2010 Dodge Ram 1500 CC
Trim Level: Sport 4x4
Rep:103
ajd76 will become famous soon enoughajd76 will become famous soon enough
OP, I've got an identical setup to your and when I towed a 7000' camper in ND (mostly flat), I was getting 8-10 mpg.
Mopar bed rails, Mopar chrome fuel door, Mopar mud flaps, Mopar door sill protectors, Mopar electronic tailgate lock, Ram LL leather shifter, DeeZee tailgate assist, Access tonneau cover, cabin air filter mod, Magnaflow Y-pipe, & Westin Platinum oval nerf bars.
Old 11-06-2013, 08:28 AM
Bozo's Avatar
Vehicle: 2013 Ram
Rep:327
Thank you for the input guys!! Any more?!
Thanks again!!!
Old 11-06-2013, 11:19 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
7400lb loaded, 6800 empty 28 foot travel trailer, '12 crew cab 4x4, 3.55s with 17" wheels gets 8.5-10mpg hand calculated in foothills going 110kmph or 68mph. the new diesel 1500 will get 14-15mpg pulling that according to the canadiantruck king challenge test results.
Old 11-07-2013, 12:16 AM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
Your stated mileage with the gasser sounds pretty typical for that trailer. You should be able to get considerably better with the CTD, I'd guess 15mpg or better.
If you're serious about it, convince the dealer to let you take it for a test drive weekend, hook it up to the camper and go 60 miles down the highway and back. Then do the same trip without the trailer and see if you can live with the ride of the 3500 unloaded.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 11-07-2013, 03:13 AM
Rep:2026
A 3500 doesn't actually ride too bad unloaded. Not near as bad as you would think. I was very surprised when I took mine for a test drive before I bought it. The front end is family comparable to the 1500 IMO (I like the front end a little more stiff) but you do notice it on the back end a bit. But like I said, it's not bad.
Old 11-08-2013, 06:10 PM
Rep:14
the new 2500 will have a coil sprung rear end, might be worth looking at
