Old 11-08-2013, 01:45 PM
Rusty289's Avatar
Rusty289 Rusty289 is offline
Vehicle: 2014 Ram 1500 Crew Cab
Rep:117
Rusty289 will become famous soon enoughRusty289 will become famous soon enough
Yup, it is. If you want the same performance gains as an aftermarket CAI without spending huge money. Get a drop in filter (stay away from K&N), add a secondary intake tube to the bottom of your air box (search the forum for threads on how to do this) and replace the intake tube between the air box and throttle body to free up some flow. That will literally give you everything that an aftermarket intake provides except the for the appearance. So if you just want the small amount of performance gain then that's a great option. If you want the performance gain and a bit of a nicer look under the hood as well then take a look at the S&B or Vararam. You just have to justify if the look of either of those intakes are worth the extra cost for you.
Thanks for the info!
If ya can't Dodge it, Ram it!!!
Old 11-09-2013, 03:40 AM
Fullmetal's Avatar
Fullmetal Fullmetal is offline
Vehicle: 2014 Ram 1500 QC
Color: Bright White Clearcoat
Fullmetal is on a distinguished road
Thanks for the info everyone!
MODS: Mopar: Bright Pedal Kit, Hard Folding Tonneau Cover, Black Aluminum Running Boards, Molded Splash Guards, Door Sill Guards; Cabin Filter, Cravenspeed Stubby Antenna, EGR Black Matte In-Channel Window Visors, 3M 20% Tinted front windows, Xenon Licence bulbs, Dee Zee tailgate assist
Old 11-09-2013, 01:34 PM
Snappy Snappy is offline
Vehicle: 2014 RAM 1500
Snappy is on a distinguished road
Can you elaborate on this? What about the K&N causes you to stay away from it?
What would you use for a drop in filter?
Old 11-10-2013, 05:47 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
The K&N filters are actually terrible filters. Read through some of the information in THIS article and see what you think. It is written for diesels but a lot of the filter performance numbers will apply to gas trucks as well.
There are some other brands listed in that article that you might want to take a looks at. I'm not sure who all makes drop in filters for the 4th gen Hemis. If S&B Filters does I would check them out. aFe would also be a great choice based on the results in that article.
Old 11-04-2014, 09:10 PM
JavaPatriot JavaPatriot is offline
Vehicle: 2014 Ram Sport R/T
Trim Level: R/T Sport
JavaPatriot is on a distinguished road
Not to mention that your stock box breathes through the fender area of the truck, taking in outside air. These "cold" air intakes all have an open box taking in air heated under the hood(engine, radiator, exhaust, A/C, etc).
Some may offer a SLIGHTLY better or smoother air flow profile, but mfr's are well aware of what is possible. Many times it is as simple as money, but all to often they don't do things the aftermarket does because their design is more reliable, or gives another advantage(MPG, torque curve placement, avoiding federal emissions penalties, on and on). Remember that being able to pull more air and make more HP means burning more fuel. How often do you use the full ability of your engine, how much difference will that 4-8hp make(trick question, NONE)? The drop in mpg will make a difference in your wallet every single mile, and you paid out the nose for a kit to make that happen.
Don't think for a second Ram would skip being able to advertise 400+hp, and 28mpg hwy with a design like AFE's if there wasn't a good reason.
just my .02
Old 11-09-2014, 04:27 PM
Osage91 Osage91 is offline
Vehicle: 2013 Dodge Ram
Rep:14
Osage91 is on a distinguished road
Honestly the mopar cai and catback are probably the worst "bang for your buck" performance mods you could spend your cash on. You would be much happier by adding a drop in filter, welding in a muffler of your choice, and using the money saved to get a tuner and custom tune. And still probably have more cash left.
