Old 11-05-2013, 03:22 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
normally the only thing they provide resistors for are your bulb out indicators so you dont have an error message on your dash, i would have to see the harness set up to be positive that you do or dont need them but, based on the normal harnessing i have seen i dont think that would be causing an issue. and someone please correct me on that if im mistaken but like i said i would need either a diagram or a picture of the harnsess to be 100% positive
Old 11-05-2013, 03:30 PM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2793
Ya getting a pic may be hard as its not pretty. It is just the basic relay with a fuse and connectors. Nothing fancy. Ya I just decided to buy them because of reading about hyperflashing and didn't know for sure if it would fix it or not. But I want these months ago before I even had issues lol.
Tow mirrors up for the haters
Old 11-05-2013, 03:32 PM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
well judging by what you are saying it sounds like you either have a ballast going bad which is causing your flickering, or possibly just a grounding issue. i would check all of your grounds first take them off clean both mating surfaces up and apply a little bit of dielectric grease and see if that helps the problem. if not that switch the ballasts side for side to see if the problem moves with the ballast. if not it is in your relay harness somewhere and that is a whole nother box of worms
I agree. The flickering would first off send me towards a ballast that was going out, especially as they were working fine up until the point where they stopped working properly.
A bad ground (I read this as loose) is possible, though I'd be more inclined to think ballasts.
Bear in mind that I'm speaking ONLY from the knowledge I have of electrical components, and NOT about HIDs. I have never played with HIDs per say, but have done lots of stuff that is electrical and lighting related.
Good luck and let us know how you make out
Exco
Bill
Old 11-05-2013, 03:35 PM
Trim Level: SXT 4x4
Rep:2793
Exco
Ya I have done tons of electrical and wiring but more with messing around with LED's and wiring RV's.. When it comes to HID's and headlights.. I get iffy lol. Can wire a whole brake controller for a vehicle.. But headlights, espcially HID's.. get confusing. I will check the grounds and everything and then I will test the ballast and see where I can find one.
Old 11-05-2013, 03:36 PM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Exco
Im agreeing that it sounds more like a ballast but the grounds is something you can check readily and it doesnt cost anything and who doesnt like happy surprises
Like i said man i highly doubt you have a resistor issue but it makes me curious how they fixed your bulb out warning light
Old 11-05-2013, 03:56 PM
Trim Level: SXT 4x4
Rep:2793
I never had a bulb out warning lol. Me and my bud installed them in december.. Magic I guess.
Old 11-05-2013, 04:06 PM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Dodges they are so bad ass they fix themselves
Old 11-06-2013, 03:04 AM
pilotalex's Avatar
pilotalex pilotalex is offline
Vehicle: 2014 Ram 1500 Diesel
Trim Level: Longhorn
Rep:52
pilotalex will become famous soon enough
Brother throw away all that harness junk they sell and buy a set of these http://www.ebay.com/itm/2PC-XENON-HI...916f05&vxp=mtr
Trust me will fix all your problems.
Old 11-06-2013, 03:53 AM
Trim Level: SXT 4x4
Rep:2793
Just commented on your thread actually.. 3rd gens are H13 bulbs and have the split filaments. You posted at the end saying how H13's which share the low/ high need a harness.
Old 11-06-2013, 01:03 PM
pilotalex's Avatar
Rep:52
Thanks for the catch. My friend had a 3rd gen but he had aftermarket headlights. Yes you need the harness because of the high and low function. Although now they sell a h13 HID bulb that has both high and low with no need of the harness was just looking at it lol.
Atached link
http://homadynamic.com/hid-xenon-lig...amp-p-194.html
its beautiful
The good part is its actually XENON low and HIGH, most kits are XENON low but halogen high.
