Old 11-05-2013, 09:16 AM
Canadian Hemi Pride's Avatar
IDFWY
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
Default Weird HID issue
I have 35W 6000k HID low with halogen high in the same bulb.
So turn truck on but not lights for running lights, pass side goes halogen, driver side flicks HID.
Low beam.. HID's works, driver side flicks off the odd side.
High beam- Passanger side goes halogen, driver side stays HID.
Anyone know whats wrong?. Thanks for the help guys.
EDit.. I do have a relay harness with a fuse. I also bought these from a shop in my city which was sopose to have a year warranty, but apparently went out of business. They are RTX HID's. Had them in since December 2012.
Tow mirrors up for the haters
Old 11-05-2013, 09:55 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
Im not quite understanding what the bold part is saying and also the herness that this shop provided you how does it split to power your highs?
Old 11-05-2013, 10:22 AM
IDFWY
Trim Level: SXT 4x4
Rep:2802
I really have to go over my grammer lol.. In Canada we have running lights, so if I turn my truck on and just use running lights instead of turning on my lows, the one light goes halogen and the other just flickers HID.
The second part is when driving the odd time, the driver side HID will shut off and usually just have to flick lights on and off 1-3 times and it comes back on.
The light are bi-exenon so they are meant to have hid Lows with a halogen high filament built into the bulb. Worked great at first lol. So the bulb has 2 filaments, HID and a little halogen in it which I never really used. I have backwired the bulb to see if the halogen would be burnt out but I managed to get it to light up on the driver side.. So it does work. Just not how it is sopose too.
Old 11-05-2013, 10:35 AM
Kamanhart's Avatar
Rep:1045
well judging by what you are saying it sounds like you either have a ballast going bad which is causing your flickering, or possibly just a grounding issue. i would check all of your grounds first take them off clean both mating surfaces up and apply a little bit of dielectric grease and see if that helps the problem. if not that switch the ballasts side for side to see if the problem moves with the ballast. if not it is in your relay harness somewhere and that is a whole nother box of worms
Old 11-05-2013, 10:41 AM
IDFWY
Trim Level: SXT 4x4
Rep:2802
Hopefully it is just a ground.. Changing ballasts will be hell. Driver side has my aftermarket alarm horn blocking it and then passanger side has my S&B in the way.
Old 11-05-2013, 10:49 AM
Kamanhart's Avatar
Rep:1045
I feel your pain man i dont have the alarm but the S&B makes it real fun
but grounding issues will make some goofy stuff happen, i had one get weird 2 weekends ago my brights wouldnt turn on and if i went to hold the switch on it would kill the lights completely but only when the brights were on and it all boiled down to one ground had an issue i hope that will do it for you
Old 11-05-2013, 11:42 AM
IDFWY
Trim Level: SXT 4x4
Rep:2802
I'm praying lol.. Will check tomorrow seeing I got class from 8-8 lol then 2 midterms tomorrow.. ahhh.
Old 11-05-2013, 11:47 AM
Kamanhart's Avatar
Rep:1045
Ouch man that is rough keep us informed though deff wanna get that straightened out for you
Old 11-05-2013, 12:06 PM
IDFWY
Trim Level: SXT 4x4
Rep:2802
Oh I will be on it the moment I get a chance. Damn midterms and tests and projects. These profs really need to learn how to spread out stuff when its all for the same program lol.
Old 11-05-2013, 02:13 PM
IDFWY
Trim Level: SXT 4x4
Rep:2802
Oh ya another thing. I have resistors at home, never installed them yet, but I bought them just in case. Would installing these help.. I think they are 50W 6 Ohms.
