Old 11-04-2013, 08:19 PM
MBR MBR is offline
Vehicle: 2010 Ram 1500 Sport
Rep:66
MBR will become famous soon enough
Default Drivers side HID turning off
In the past couple of weeks my drivers side HID is not turning on at times, most of the time it will go off after 5 min or so of driving. Other than checking that all the connections are clean and good ground anything else to look for?
It's a kit from Retro Solutions the I've been running for about 3-4 years
Old 11-04-2013, 08:22 PM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Weak Ballast possibly?
3 or 4 years a fairly good time period with no issue.
I would say swap the ballast with your passenger side one, if the problem moves over to your pass side. Replace the ballast.
Old 11-04-2013, 08:26 PM
DevinC's Avatar
DevinC DevinC is offline
Rep:193
DevinC has a spectacular aura aboutDevinC has a spectacular aura about
Yup, do what Bordin said. I'm also betting it's the ballast.
Old 11-04-2013, 08:55 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Agree, swap the ballasts, you will see if its a bulb or the ballast, could also be your relay, start with one thing, then if it continues could be bulb or relay, swap bulbs, then see. let us know what you find.
Old 11-14-2013, 10:01 AM
MBR MBR is offline
Rep:66
I ordered a new ballast and got it installed earlier this week and have not had any problems since, thanks for the input guys
Old 11-16-2013, 11:00 AM
Thundertek2002 Thundertek2002 is offline
Vehicle: 2013 Dodge Ram
Trim Level: Sport 4x4
Thundertek2002 is on a distinguished road
I've had this problem with my hid fog lights. They will be fine for the first 5 minutes or so and then the right one will go out. If I turn the fogs off, wait 5 minutes and then turn them back on again they'll work for at least another 20-30 minutes before it'll go out again.
When I first installed the 55w kit in the fogs the drivers side would blink and then turn off after 15 seconds. I purchased an error corrector module and this seemed to fix it but lately I'm seeing the passenger one going off after around 5-10 minutes.
I was told on the 13 Rams there's something that senses the voltage and automatically turns one side off if it senses too much. That's what the corrector module is supposed to take care of.
Old 11-16-2013, 11:24 AM
Vehicle: .
Rep:4371
Are you using a wire harness or a canbus ballast?
