Old 11-04-2013, 10:49 AM
Glockem Glockem is offline
Vehicle: 2012 Dodge Ram
Glockem is on a distinguished road
Default Jeep project complete on to the RAM
I just finished my jeep project and now onto my 2012 Ram. I have a new set of BFG Mud Terrains in 305/60R KM2 in 18's. My Ram has 20's can I buy Rims to accomidate the tires I have? What are the bolt patterns for my Ram? Pictures would be good, and thanks.
Old 11-04-2013, 01:26 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
the bolt pattern in 5x5.5
you wont be able to fit 305s on stock ram tho. 285 is about as wide as you can get without rubbing.
what do you want pictures of??
Old 11-04-2013, 01:33 PM
Default Leveling Kit
If I go to a leveling kit will the 305's fit without rubbing? Seems it equates to a 33 inch tire. What leveling kit would you guys recommend?
Old 11-04-2013, 01:37 PM
Rep:1900
yes with a leveling kit you'll be fine. you might need 1/4" spacers though. Or buy new wheels that are at least 0 offset.
bilstein 5100 adjustable shocks are hands down the best way to level these rams
Old 11-06-2013, 03:05 AM
hodge's Avatar
hodge hodge is offline
Vehicle: 2011 Dodge Ram Sport
Rep:26
hodge is on a distinguished road
I think you'd be fine running those tires with some wheels spacers. They're basically the same height as stocks just wider, so the spacer will help clear the control arm. Otherwise you shouldn't have an issue.. they may even look small with a level installed but who knows. You'll need the wheel spacer regardless on stock rims.
RCX 2.5" level - 1.5" Zone Body Lift - 295/65/20 Trail Grapplers - 20x10 Moto Metal 970 - Debadged - 18" Magnaflow and Y-Pipe - S&B CAI - DiabloSport Intune DCX
Old 11-21-2013, 01:57 PM
beakerztoyz's Avatar
beakerztoyz beakerztoyz is offline
Vehicle: 1985 dodge w150
Color: burnt orange & grey
Engine: 1981-1988 360ci (5.9L) LA V8 170hp
beakerztoyz is on a distinguished road
You should talk to your local tire shops about this, lots of times aftermarket rims can be ordered in different backspacings, so you might be able to get some wheels to work without spacers.
Old 11-21-2013, 08:47 PM
aparini's Avatar
aparini aparini is offline
Vehicle: 2012 Ram 1500 QC 4x4
Trim Level: TANK
Color: Gloss Black Bedliner
Rep:159
aparini has a spectacular aura aboutaparini has a spectacular aura about
personally i have Ballistic Jesters 18x9 with -18 offest ( i believe ) and I barely rub with 35x12.5 Trail Grapplers. I only have a 2" leveling kit by Ready Lift... 100% agree you should go with the 5100 Bilstiens for your leveling kit... They can be used with a lift should you decide to go bigger later... Im about to rip my Spacers out and put the 5100s.
Jezebelle
Bedliner Paint Job * 2" ReadyLift *18" Ballistic Jester -18mm * 35x12.5r18 FUEL Mud Grippers * Iron Cross Bumper * 12.5lbs Badlands Winch w/remote * 4" Side Steps * Bullydog GT
Old 11-22-2013, 04:58 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
where are the pics of said jeep?
Old 11-24-2013, 12:21 AM
HULK's Avatar
HULK HULK is offline
Vehicle: 2007 Dodge 4X4 (HULK SMASH)
Trim Level: SLT Lone Star 4x4
Color: Gun Metal Grey
HULK is on a distinguished road
If your truck is not 4x4 you probably can't run 305's.
But my first set of tires I Had 305/55/20's Stock Wheels. BFG A/T. I had no issues with rubbing even when I maxxed out the turning. But my truck is 4x4 so it sits a little higher. I only got 40K out of those tires tho.
Now running 285's IDK why I chose this size probably cause i wanted to save money but NOW I am Getting 35's with my bilistine lift.
So If you have a 4x4 then You can safely run 305's IMO
2.8 level, Train horn, bed cover, headlight brows, blackout grill fins, side steps, reverse work lights, Cameo neoprene seat covers, catchalls, onboard air system.
Old 11-24-2013, 08:37 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
x2...................
Sean
