Old 11-04-2013, 10:27 AM
BlackedOutNinja's Avatar
BlackedOutNinja BlackedOutNinja is offline
Vehicle: 2013 Ram Sport
Trim Level: sport
Rep:56
BlackedOutNinja will become famous soon enough
Question 2013 4X4 auto
So the snow flew yesterday and the roads were stupid icy. Im just wondering exactly how the 4X4 auto setting works? what are some pros or cons compared to using 4X4 lock? Will the auto engaging and disengaging wear anything out?
Thanks.
Brrraaaaaaapp!!!
Old 11-04-2013, 10:55 AM
RPM666's Avatar
RPM666 RPM666 is offline
Vehicle: 2012 RAM 1500 LL Limited 4x4
Color: True Blue
Rep:363
RPM666 is just really niceRPM666 is just really niceRPM666 is just really niceRPM666 is just really nice
I believe 4x4 auto allows for limited slip when turning so you can use it on the highway\dry roads.
4x4 Lock does not and is not intended for use on roads or dry surfaces.
S&B CAI // Flowmaster 50 Series HD // Bilstein 5100's @ 2.8" // Lockpick V5 // Hypertech Interceptor // Cabin filter mod // BP Polished Catch Can // TonnoPro LoRoll Cover // 4 Digit Combo Console Vault // Escort 8500 X50 Blue // GumCreek Vehicle Holster
Old 11-04-2013, 11:00 AM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:33
theGSE10 is on a distinguished road
I always thought AUTO acted sort of like an adaptive AWD in that it uses 2wd until the wheels start to slip at which point it would engage 4wd to compensate for the loss of traction. I could be wrong though....does anyone know?
Hellwig rear sway bar / Green filter / Borla XR-1 / Line-X / Bak Roll-X / AMI shorty antenna / Raptor 4" nerf bar / Mopar tow hooks / Moroso Catch Can / Bilsteins @ 2.1 / Fox 2.0 rear / TGC .75 rear spacer / Air Lift 1000 / Bak Box 2 /
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
Old 11-04-2013, 11:54 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
the system will have the 4wd system engaged but i do believe when one of the wheel sensors trips from a wheel slipping and turning faster than the rest it engages the front driveshaft to enhance traction and control. if it's the same type of system used on the jeep grand cherokee it's a great system. for 10 years my grand cherokee would be put in part time 4wd in fall at first snowfall and stay there until spring. it always worked flawlessly. dont use full time 4wd unless your in a snow storm or off roading part time 4wd is designed for adverse road conditions. not for high speed driving.
Old 11-04-2013, 12:04 PM
Trim Level: sport
Rep:56
thanks for your info guys, so it sounds like its safe to ride 4X4 auto at highway speeds??
Im sure this info is in my maunal?
Brrraaaaaaapp!!!
Old 11-04-2013, 12:20 PM
theGSE10's Avatar
Rep:33
Yep, auto is safe to take up to hwy speeds. It should be somewhere in the manual as well, though I think they tell you to try and limit it to 55mph.
Old 11-05-2013, 09:29 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:528
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
Correct me if I'm wrong but from what I understand it works sort of like an electronic auto locking differential but its the transfer case rather than the diff, meaning that in 4wd auto it will be in 2wd until the truck senses slip. Upon sensing slip in the rear wheels the front wheels will engage. It will then disengage to avoid binding the transfer case when your rear wheels regain traction.
That's why its called full time 4wd, because you can have it on full time, even on dry pavement and it will not damage your 4wd system. Part time 4wd can only be used when you are in slippery conditions because turning with it engaged on dry pavement will bind your transfer case. The 4wd lock and 4low settings are both part time settings. I believe the manual says not to use 4lock or auto above 55mph and not to use 4wd low above 25mph. With the 4wd auto you could probably go as fast as usual as long as you're on pavement though. I personally think 55 is too fast to be driving in situations where you actually need 4wd.
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread).
Old 11-05-2013, 10:17 PM
Canadian Hemi Pride's Avatar
Watch it crash and burn
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2793
If the auto is anything like GM has had for years. It will stay in 2wd until it recognizes 4x4 is needed. I sadly don't have this option.. 4x4 high and 4x4 low ... The auto is a great system to have.
Tow mirrors up for the haters
Old 11-06-2013, 10:06 PM
llsht14's Avatar
llsht14 llsht14 is offline
Vehicle: 2011 Ram 2500 Megacab Cummins
Rep:25
llsht14 is on a distinguished road
The 4x4 auto is one of the reasons i sold my 1500. The 4x4 auto works good like it should. but in trucks with the 4x4 auto option the 4x4 lock option doesn't actually lock like it would in trucks without the auto option, its the way the transfer cases are set up.
2011 Ram 2500 Laramie Megacab Cummins, afe intake, h&s egr delete, flo pro 5" turbo back exhaust, 6 in tip, mini maxx tuner
Sold--- 2011 Ram 1500 Sport
Old 11-07-2013, 01:46 AM
hodge's Avatar
hodge hodge is offline
Vehicle: 2011 Dodge Ram Sport
Rep:26
hodge is on a distinguished road
What do you mean the truck doesn't actually lock?
From my experiences, the 4wd lock means your transfer case is "locked" into 4wd and is constantly transferring power to your front diff just as it is your rear. When the snow is really flying or roads are extra slippery, I use this option.
4wd Auto, as others have stated, is automatically transferring power to your front wheels as it senses your rear wheels slipping. I find in my ram there is a pretty solid delay between rear wheel slippage and front wheel engagement. You can get pretty squirrely before your front wheels start to pull and straighten you out. Not really sure of ratio of rear spin to 4wd engagement. I use this all winter when it's not super bad out because you're basically driving around in 2wd unless you start to spin.
I can't see any issues with exceeding 55 while in auto.. the only problem would be if you somehow started spinning and the 4wd engaged at these speeds. For one it would cause some pretty unpredictable results and two I'm sure it'd be pretty stressful on your drivetrain at that speed, especially if you then caught traction again.
Just my 2 cents...
RCX 2.5" level - 1.5" Zone Body Lift - 295/65/20 Trail Grapplers - 20x10 Moto Metal 970 - Debadged - 18" Magnaflow and Y-Pipe - S&B CAI - DiabloSport Intune DCX
