Old 11-02-2013, 02:59 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Default Taillight LED Bulb 80watts 900 lumens
I have installed and tried a ton of 3157 taillight bulbs since I have my truck, seriously at least 10 sets of Bulbs, my last set I had on my truck was about the same output as a stock bulb. I have been looking for a brighter bulb and recently found these from autolumination and they are probably the brightest replacement bulb you can find, not cheap but they are way brighter than the stock 3157 which produces around 600 lumens, this LED Bulb with 16 Cree LED's produces 80 watts, around 900 lumens.
I picked these up from Autolumination
http://autolumination.com/3157_3156.htm
So if your looking for a bulb to replace your stock bulb and want something brighter these will work.
Old 11-02-2013, 05:22 PM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
Awesome find!! Do they come in a s*ck base as well or just a regular 3157 base?
Old 11-02-2013, 08:39 PM
Vehicle: .
Rep:4371
I picked the up in the 3157 base ver, did not check if they had other versions.
Old 11-02-2013, 08:41 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Most excellent. Gonna have to give these a look. Thanks for the info.
Old 11-11-2013, 02:51 PM
fastforwarddad fastforwarddad is offline
Vehicle: 2012 Laramie 4X4 Crew Cab
fastforwarddad is on a distinguished road
wondering how these will compare to the V LEDs Triton in real the real world
http://www.vleds.com/v3-triton/bulb-system/v3-r.html
I am most concerned with their operation in bright sunlight.
Have you installed yours yet?
Old 11-11-2013, 04:20 PM
Vehicle: .
Rep:4371
Installed and very bright, brighter than stock bulb, love these, very nice.
Old 11-11-2013, 06:54 PM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
Did you take any before and after pics? I'd love to see them installed.
Old 11-11-2013, 07:40 PM
Vehicle: .
Rep:4371
Nope since I had other LED bulbs for a while, I could always take daytime pics so you can see how bright they are, but pictures are relative to the camera etc, so they don't really give you a thought of how bright they really are since the camera will try to correct for crappy lighting or for too much lighting. All I can say is I tried around 7 sets of bulbs, after about 6 months I had found a set that was around a 600 lumans bulb, I liked them but wanted something stronger, and these 900 lumen 80watt ones are very strong.
Again its never easy to get the proper brightness effect with a phone camera but here they are lighting up my garage door with the brake lights, as you can see there pretty strong, and no problems seeing the in the day full sunlight, they are brighter than the OEM bulbs. These are the 3157 super white bulbs since the brake light housing is red.
Old 11-12-2013, 12:29 AM
Brad Pitt's Avatar
Brad Pitt Brad Pitt is offline
Vehicle: 2013 RAM 1500
Rep:93
Brad Pitt will become famous soon enough
Thanks for the info... got anymore pics?
Old 11-12-2013, 08:58 PM
Rep:97
Thanks. Those do look really bright.
