Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 10-31-2013, 09:35 PM
ty-wa's Avatar
ty-wa ty-wa is offline
Vehicle: 2014 Ram 1500
Trim Level: Tradesman/ Express
Color: Blue Streak
Rep:88
ty-wa will become famous soon enough
Exclamation help, help, help, Spacers?
I have a rough country leveling kit on my 2012 ram 1500, 2.5 in the front and 1.75 in the rear; I found a set of Terras with 7000 miles on them, 325 60 R20's for 550 with a set of hummer wheels with them (which I would scrap/sell) is this a good deal? and if so
WHAT SIZE Spacers do I need to run if I get them, 1/4? 1inch centric? Hopefully 1/4 will work.
Too many different answers online.
Help please. Thanks.
-Ty-wa(Z) here
Old 10-31-2013, 10:33 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
That might fit without the spacer. They're basically 35.4 x 12.8. You might get away with it since they're Terras not Trails. I would go for it. If they rub, it will be light and you can pick up spacers at that point.
Simon
Old 10-31-2013, 10:46 PM
ty-wa's Avatar
Color: Blue Streak
Rep:88
Are shims (or 1/4 spacer safe though?) And thanks for the 2nd reply by the way! I really appreciate it. And do you think thats a good deal? Or should I pay 1600 for 35x12.5 new?
-Ty-wa(Z) here
Old 11-01-2013, 06:33 PM
LowUFO's Avatar
Rep:1105
No problem. That's a sweet deal. I would do it for sure. So cheap. But let me amend my previous post (which I had already amended) back to what I first thought. Reading other threads, it seems ppl can run that size w aftermarket rims w a lower offset like -12 and have no rubbing. But on the stock rims, you will probably need a 1" adapter to clear. Spacers and adapters are safe to use when used properly. Especially adapters which use their own bolts to mount the wheel and your bolts to attach to the hub. Check out http://www.motorsport-tech.com/bora.html for the best quality adapters out there. Other than the cost of the adapters, the only other catch is that between the adapters and the tires, the outside wall of the tire will now be 2" further out than stock which means you can throw a lot of crap off the tires onto the bodywork if you drive on dirt roads. It will destroy your paint.
Simon
Old 11-10-2013, 07:20 PM
ty-wa's Avatar
Color: Blue Streak
Rep:88
Default Did it..
Ended up finding a set of Mickey Thomp ATZ that I couldn't say no to...35x12.5R20. Looks amazing! Thanks again!
-Ty-wa(Z) here
Old 11-11-2013, 06:37 PM
LowUFO's Avatar
Rep:1105
Am I blind? Where are the pics?
Simon
Old 11-11-2013, 10:35 PM
ty-wa's Avatar
Color: Blue Streak
Rep:88
Default Duh...my bad.
Oh yeah! haha.. heres two of them.!
-Ty-wa(Z) here
Old 11-12-2013, 07:58 PM
LowUFO's Avatar
Rep:1105
Oh yeah, that looks good. Rubbing at full lock?
Simon
Old 11-13-2013, 10:17 AM
ty-wa's Avatar
Color: Blue Streak
Rep:88
Default About that..
At first, yes, but I got an alignment the next day, and believe it or not, they don't rub but a touch, which isn't noticeable except to the driver (me). So they don't really rub at all.
-Ty-wa(Z) here
Old 11-14-2013, 01:03 AM
LowUFO's Avatar
Rep:1105
Just when you've got the wheels turned fully to one side or either side?
Simon
lift, nitto, ram, spacers, tires
