Old 10-30-2013, 05:21 PM
rockyram21 rockyram21 is offline
Vehicle: 2009 Dodge Ram Hemi
Rep:26
rockyram21 is on a distinguished road
Default Calling any B.C. Boys
Still debating lifting my 2009. It'll look cool but performance loss and MPG loss I think I can live with but then I thought of something else. I'm wondering if there are any Motor Vehicle Branch laws about lifting vehicles. Years back I had a 1982 Toyota with a 6" lift on 35's and got hassled by the cops. Finally had to take it to a licensed inspection facility. I used NSOR. Don't want have to go thru that again. If anyone has any insight I'd appreciate it. Cheers
Old 10-30-2013, 05:36 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I had my 1500 lifted with a 6" lift and Bilsteins at 1.4" (so 7.4" of lift) and 35x12.5 Toyo MT's on 20x9 -12 offset wheels. The tires stuck out approximately 2" past the fender on the front (pics linked in my signature below if you want to take a look). I went through a few different DUI checks with it and the cops didn't say anything about it. That being said, it only takes one dink of a cop to send you in to get an inspection.
You won't have any problem with a 6" lift on a Ram. Just make sure your headlights are adjusted properly so you aren't blinding people. It's the tires sticking out that has the potential to give you a problem. The rule of thumb is that if you drop a coin from your fender (or flare) it can't hit the tread of the tire. The side wall is allowed to bulge out slightly, just not the tread. But you could run flares and then be 100% legal. So no matter what you can make it work.
Old 11-01-2013, 03:42 PM
Rep:26
Thanks for the reply. Good to know.
