Old 10-30-2013, 12:17 AM
Traker82's Avatar
Traker82 Traker82 is offline
Traker82 is on a distinguished road
Default LED off road light install
Hi guys, I am installing 4 lights on to my back rack and I had a few questions;
1) There are 4 LED lamps which draw 1.9A on a 12volt system, can I wire all four together or should I do 2 and 2.
2) Should I use a 30-40A relay or should I just go to the battery using an interrupt.
3) is 12ga wire good or should I use smaller?
I think that covers it.
Old 10-30-2013, 11:21 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
(1) You can wire all 4 lights together or 2 and 2.
(2) Use 1 relay for 4 lights or 2 relays for 2 and 2. 30 amp. or 40 amp. relay.
(3) 12ga. or 14ga. is fine and use a 10 amp. fuse before the relay. Watch the short video.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-30-2013, 11:32 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Greg
Ditto on what he said LED's don't use to much power at all
Old 10-30-2013, 01:45 PM
Traker82's Avatar
I am switching out from Halogens just so I can use the lights on just battery if needed.
Thank you guys!
