Old 10-28-2013, 11:16 PM
topsub topsub is offline
Vehicle: 2012 Dodge Ram Laramie
Color: Blue
Rep:147
topsub will become famous soon enoughtopsub will become famous soon enough
Default How to take off headlight deflector
How do i remove this piece?
I've looked but can't find an easy way unless i'm missing something?
2012 Dodge Laramie 4x4 CrewCab
My Build Progress
Old 10-28-2013, 11:32 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
As far as I know that doesn't come off.
I could be wrong but that is my first guess.
Chrome... in moderation.
Old 10-28-2013, 11:41 PM
Color: Blue
Rep:147
Boo how to mount retrofit?? :-(
EDIT: Guess worst case i'll cut the mount, the Projector with shrouds should cover them. ( i hope )
My Build Progress
Old 10-29-2013, 09:10 AM
Asur Asur is offline
Vehicle: .
Rep:4371
The reflector pops out, its held in place by 3 clips, its like the headlamp housing clips, its a nipple that fits into a clip on the back of the housing, when I pulled mine off to install the projectors I used a plastic dash tool, the larger one and pulled it off the housing. That reflector is pretty solid at the rear of it, just still got to be careful of the front sides area. This is what it looks like from behind the reflector
Old 10-29-2013, 09:17 AM
Color: Blue
Rep:147
The reflector pops out, its held in place by 3 clips, its like the headlamp housing clips, its a nipple that fits into a clip on the back of the housing, when I pulled mine off to install the projectors I used a plastic dask tool, the larger one and pulled it off the housing. That reflector is pretty solid at the rear of it, just still got to be careful of the front sides area. This is what it looks like from behind the reflector
What is the best way to remove teh chrome housing from the headlight housing? I saw some screws but those look hard to get to
My Build Progress
Old 10-29-2013, 09:39 AM
Vehicle: .
Rep:4371
I used a plastic pry tool, to push off the housing using the back of the reflector, and pulling with my hand, it will pop out, just watch the front of the reflector as its thin.
The larger one is what I used, but all you need is something to help lift as you pull, you could probably use other tools, I am just telling you what I did and used
Old 10-29-2013, 10:52 AM
Color: Blue
Rep:147
Awesome good info, I happen to have 2 sets of those PERFECT!
Yep was able to pry one of the pop things off, then pushed with my hand gently, Got them apart, Perfect! Painting time!
My Build Progress
Old 10-29-2013, 12:00 PM
NCBEAST NCBEAST is offline
Rep:16
NCBEAST is on a distinguished road
Are you planning on painting the reflectors as well or just the bowls?
Old 10-29-2013, 12:06 PM
Color: Blue
Rep:147
I'm gunna run at lunch and trab some tint paint.
http://www.autozone.com/autozone/acc...ier=87705_0_0_
And Try to tint them a coat or 2
My Build Progress
Old 10-29-2013, 04:19 PM
Color: Blue
Rep:147
I'll post an update here:
Welp got them apart:
Here we go:
Light coat of primer:
Gonna paint everything you see matte black, Then the shrouds color match the truck.
Found some Tint stuff, Very Pricey @ $12 a can
Before:
Primed and ready to go:
2 Coats of tint:
prob 4-6 Coats of Matte Black ( Still Wet )
So here is the final paint and mock up. I will be ordering the projectors today.
Didn't want to snap them in but mock up:
My Build Progress
