Old 10-30-2013, 12:39 PM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
Dam he's (gcscott) good
Old 10-30-2013, 08:18 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
I think I'm going to try to fix it for now and hopefully its a simple fix. Maybe in a week or two I'll try adding a relay to it...theres an event coming up Friday where i need to show it off and I feel like adding a relay will take more than a day for me.... plus I just bought a new sub box that I have to get everything hooked up too.
Green Interior LEDs
Old 10-31-2013, 04:29 PM
Rep:529
so radio comes on when i unplug all the LEDs from the main source.
all LEDS work when hooked up to a 9v battery.
does this mean that the problem is somewhere in the stock wiring? Am
I drawing too much power?
Will a relay fix this? thanks
Green Interior LEDs
Old 11-01-2013, 10:21 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Well if your radio now works and the fuse has stopped blowing i would say the LED lights were your problem. If I remember you have a lot of LED lights & fans connected to your electrical system. I would put them on a separate circuit just to be safe and you will have extra power for expansion. Don't over load the wire with drawing to many amps. LED lights have a small drain, but when you add them up you can draw some real current (amps.)
My bed lights, I have 300 LED'S (1, 16'-4" roll 5050 LED's) draw about 6.5 amps. so they do add up and I have them on a separate 7.5 amp. circuit with relay. A 9 volt battery will light them up, but it won't last very long.
I put yellow/orange LED 5050 lights on the rocker panel edge for running lights. There are 105 LED per side and just one side draws 2.2 amps. of power.
Like I said, LED lights have a small power draw but add up quickly in large amounts.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-01-2013, 11:34 AM
Rep:529
Greg
I don't have the fans anymore. haha . They were blue, now my truck is green, they don't fit too well anymore...
So if I add a relay to make its own circuit, triggered by the dome light wires, it shouuulddd work?
What size fuse should that be? Its 4 of a brighter strip, then 2 of a normally bright strip, then 2 half size normally bright strips.
Green Interior LEDs
Old 11-01-2013, 02:18 PM
gcscott's Avatar
Rep:1043
Question #1 yes.
Question #2 The definition of brighter doesn't mean much.
Since I do not know how much amperage each LED strip draws, which you have 3 different types, sizes, excreta.
I would be very conservative and use a in-line 5 amp fuse installed with-in 1 foot of the fuse box or battery terminal, than 14 gauge wire to relay terminal #30.
Then run 14 gauge wire from relay terminal 87 to your LED lights. JMO.
14 gauge wire can handle a maximum 15 amp load to up to 20 feet. Always use a lower amp. fuse when possible and a shorter length of wire.
Wiring chart for referance: http://www.tessco.com/yts/industry/p...get_wired.html
Greg
Old 11-02-2013, 12:19 AM
Rep:529
thank you very much!
Green Interior LEDs
interior, led, lights, problem, radio
