Old 10-28-2013, 07:38 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
Question No Radio; No interior LEDs
Well this thread includes problems with my radio and interior leds, I'm posting it here because more people view these threads versus the interior LED threads.
I recently installed interior Leds, THREAD HERE, and I thought everything went well, but apparently not!
I was removing the back panel, not sure what its called, the one with the hooks and stuff behind the back seats under the window. Finally removed it and realized my Interior LEDs were off. I'm like "crap, I forgot to turn off my led's and now my batteries probably dead. (It took us a little while to take out this panel...) I go ahead and try to start it anyway and it started just fine. So im like "Well shit." then I noticed my radio wasn't turning on either so once again I'm like "Well, Shit."
I start searching for fuses everywhere and Amongst my many Add-a-Circuts i finally found the culprit, My I.O.D fuse was blown. And Of course i have NO extra fuses anywhere. The next day i venture to O'Reily and buy some of those nifty Smart fuses that glow when they blow. I bout a 2 pack of 10 amps and a 2 pack of 15 amp. I stick the first 10 amp fuse and it blows. i like, "well, shit". I figured even though i never bother unhooking my ground when i play with fuses, that must have been the problem. So i pop the hodd in the parking lot and proceed to unhook the ground.
I stick the fuse in, nothing blows, (obviously, the ground is unhooked.) I connect the ground and look at the fuse, what do you know, its glowing! so that fuse blew too. Then i thought maybe or some reason Im just using too small of a fuse. So I pop one of the 15's in; it blows as well.
So now I'm thinking what the hell is wrong here. So I go into O'Reily again and ask the old grumpy and cranky clerk and tell him what just happened. He quickly and snappily states " You got a direct short" and then continued to not explain what might have caused it, where it could be located or anything useful whatsoever.
So before I start ripping everything out, Could it be one of my led wires came out somewhere? any ideas will help.
Thanks
Air horn "AHHOOOGA" horn,
Green Interior LEDs
Old 10-28-2013, 08:19 PM
Canadian Hemi Pride's Avatar
Canadian Hemi Pride Canadian Hemi Pride is online now
Watch it crash and burn
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2793
Hm I don't know an exact answer as to why the LED's and radio would be off.. But ya all I can say is to start searching through all your wiring for any loose ends or something that could cause both to go off.. All of your fuses in the fuse panel are good though?
Tow mirrors up for the haters
Old 10-28-2013, 08:34 PM
Rep:529
all of them except that I.O.D fuse.
Green Interior LEDs
Old 10-29-2013, 10:34 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Well the store clerk is correct, dead short, and he would not know where the problem would be.
(1) I would first disconnect all of your wiring mods. where you tied into the factory wiring or fuse box.
(2) Replace the I.O.D. fuse, with the correct rated fuse and see if it blows.
(3) If the I.O.D. fuse does not blow start connecting 1 circuit at a time to see which one is the problem. If 1 circuit works correctly disconnect it and go on to the next one until you tested all the circuits.
(4) If the fuse blows you found which circuit is your problem and you know where to start looking for the short.
(5) After you fix the short now you can connect each circuit one at a time to see if the I.O.D. fuse does not blow. If the I.O.D. fuse still blows you have to much stuff connect and need to go directly to the battery and start using relays for each circuit that you added.
Hope this helps.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-29-2013, 11:46 AM
Rep:529
Hope this helps.
Greg
that was basically the answer I was hoping i wouldn't have to do! haha. looks like ill tear everything out tomorrow!
Green Interior LEDs
Old 10-29-2013, 12:31 PM
Trim Level: SXT 4x4
Rep:2793
When it comes to wiring problems.. It will never be a simple procedure.. Gonna be a painful step by step.
Old 10-29-2013, 01:27 PM
gcscott's Avatar
Rep:1043
That is why I always use and recommend you use a relay and a fuse for each circuit that you add to your wiring. If the circuit shorts you know where to start looking.
Old 10-29-2013, 11:43 PM
Rep:529
how would I tie a relay into the leds through the dome lights?
Green Interior LEDs
Old 10-30-2013, 10:47 AM
gcscott's Avatar
Rep:1043
You use the dome light power wire to trigger the relay.
To trigger the relay through terminals 85 (- ground) and 86 (+ dome light) on the relay.
Power from battery through fuse to terminal 30 on relay.
Terminal 87 or 87A to your accessory. Most use terminal 87, but you can use terminal 87A, or you can use both 87 and 87A. Watch the video.
Greg
Old 10-30-2013, 01:17 PM
Rep:529
Thank you very much!
Green Interior LEDs
interior, led, lights, problem, radio
