Old 10-27-2013, 01:01 PM
Frankf300's Avatar
Frankf300 Frankf300 is offline
Vehicle: 2014 Ram 2500 CTD
Color: Bright White Clear Coat
Rep:104
Frankf300 will become famous soon enoughFrankf300 will become famous soon enough
Default Switching from 20" to 17"
I swear I have been searching the forums and google for answers, but if they are there and I missed them...my apologies and feel free to bash away lol! I have a 2012 Ram 1500 4x4 Crew that has the stock 20x9 wheels on it. I'd like to get a 17" wheel package and keep my 20s in the garage when I get the urge to put em on. I want more tire, less rim. I can't find any definitive answers on my questions though. What offset and backspacing would I need to keep it pretty close to stock? I definitely do not want to stick out anymore than it is now. I found a set of wheels I really like...here are the specs: 17x8, 00mm offset, 4.45" backspacing. Also, what is the biggest 17R tire that I can squeeze in there? I'm stock, no lift, no level. Any help is greatly appreciated since I have been chasing my tail on this lol!
Traded in the Hemi
2014 Ram 2500 Crew Cab 6.7 CTD
Old 10-27-2013, 01:43 PM
dig dig is offline
Vehicle: 2010 1500 Dodge Ram Crew Cab
Trim Level: SLT- Big Horn
Rep:19
dig is on a distinguished road
I went with Michelin 275/65R20 LtX These tires gave me 1.5" more on the side wall then the OEM HP's I really like them.
Old 10-27-2013, 02:24 PM
MangoTangoMofo's Avatar
MangoTangoMofo MangoTangoMofo is offline
Vehicle: 2010 1500 Sport 5.7L Hemi
Trim Level: Sport Quad Cab
Color: Mango Tango
Rep:98
MangoTangoMofo will become famous soon enough
Since you are planning on dropping to 17”s and want to keep a stock look, try and find a rim as close to the stock setup which has a +19 offset and is 9 inches wide. If you want a slightly larger tire than stock without a lift or level you might need to push your rims out a little bit (like a +12 offset rim) to avoid any rubbing, but you should be ok with a stock offset and 285/70/17.
Below I attached my favorite tire size calculator that gives you actual sizes and a visual representation, this way we can give you suggestions and opinions and you can check for yourself and make your own judgment call.
http://www.tacomaworld.com/forum/tirecalc.php
Best of luck!
5x11x22 Magnaflow with a resonator delete // Rough Country 2.5F&1.75R level kit // 17 XD Cranks // 35x12.5x17 Toyo MT's // Air Lift 1000 // Armor Thane bed liner // Century Ultra Sport Canopy // Yakima Roof Rack // Mopar side steps // Custom Browning Mudflaps
Old 10-27-2013, 07:31 PM
Frankf300's Avatar
Rep:104
Thanks! Very helpful! So I've found some 17s that are very close to stock with the offset, but I really wanted to try and squeeze a 34" tire on there since I've read that's the most that stock will accommodate, but I can't find much for a 17" wheel! I also read that 285 is the widest that can go in there without spacers, but if I get a 17x8 rim does that give me a little more wiggle room to go wider? I really wanted to do a level kit, but I've heard differing views on them and was trying to avoid it for now even for warranty purposes. Honestly, I love the look of tires that stick out past the fenders, BUT I'm worried about all the crap it's going to kick up since I don't have mud flaps.
Traded in the Hemi
Old 10-27-2013, 10:39 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
The only way to go to a wider tire, is to go w a lower offset wheel. And/or a level or a lift kit. A narrower rim will make the tire sit slightly taller and narrower but not a lot. You're better off going w a 17x8.5 w a zero offset and a 285/65 11.2" wide x 7.3" of sidewall and will sit 24mm further out than your stockers) or 295/60 (11.6" wide x 7" of sidewall and will sit 29mm further out than your stockers).
Your stock tire is 10.8" wide x 6.5" of sidewall.
Simon
Old 10-27-2013, 10:51 PM
LowUFO's Avatar
Rep:1105
But putting Bilstein adjustable front struts at 2.1" setting on the front Would finish off the look nicely. Literally thousands of people are happily running them.
Simon
Old 10-27-2013, 11:50 PM
Frankf300's Avatar
Rep:104
The rims that I really want also come in an 18x9 with a 18mm offset. I was also considering that to get me closer to stock offset. I really wanted to go 17s, but I really like these rims haha. If I go with the 17 it has the 0 offset and I'm just worried about how much they are going to stick out of the fenders. I like the look, but with no mud flaps or flares I don't want to be slinging up road debris and gravel and all that crap up on the body.
Traded in the Hemi
Old 10-28-2013, 12:14 AM
Radak04's Avatar
Radak04 Radak04 is offline
Vehicle: 2013 Ram Sport Crew
Rep:76
Radak04 will become famous soon enough
Go with 18s with the + 18 offset. You won't be disappointed. (Says the guy with that exact setup)
If you put 275/70R18s on them, you will be nearly identical to stock. Speed will be right and it will look good
Old 10-28-2013, 12:18 AM
Frankf300's Avatar
Rep:104
Have any pics? Do you feel like you could have squeezed any more tire in there though haha? I plan on going with a much more aggressive tread so I'm hoping that will kind of fill in the wheel well anyway.
Traded in the Hemi
Old 10-28-2013, 12:46 AM
Radak04's Avatar
Rep:76
You could easily fit bigger tires. This is my winter setup, so fatter tires is counter productive.
Tires are Goodyear DuraTracs.
