Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 10-26-2013, 08:57 PM
devout3ebfan's Avatar
devout3ebfan devout3ebfan is offline
Vehicle: 2005 Dodge Ram
Trim Level: 1500 Laramie
devout3ebfan is on a distinguished road
Default What would I need to run 38x15.5x20 on a 6" lift
Hello,
I need some advice. I would like to run 38x15.50x20 tires and 20x12 wheels on an 05 1500 QC 4x4...
My initial plan was a full 6" suspension lift + 3" body but I know just how wide those tires are and I would need to do some trimming right? How could I avoid all the trimming? I also don't want a whole lot of offset. I think what I can get with the 20x12s is -44 and thats the right amount of tire I want sticking out under the fender. My next consideration were the 37x13.50x20s but I do like the look of the 38s better. Help!
Thanks,
Carson
Carson
Old 10-29-2013, 01:29 PM
HOOAHHemi's Avatar
HOOAHHemi HOOAHHemi is offline
Vehicle: 2006 Dodge Ram 1500
HOOAHHemi is on a distinguished road
I have an '06 with a 6'' BDS lift. I am running 37x12.5 Nitto Trail Grapplers on 17x9 XD Addicts. The truck shop that did the install recommended 35''s, BDS said 37''s will fit. Naturally I went with the 37''s. At full lock, with the front suspension compressed, I have minor rub. For example pulling into a raised driveway with enough speed to compress the suspension and the wheel hard over. Other then that I have no issues with rub. My friend has 38x15.5 Baja Claws on his F350 with an 8'' lift and when I park next to it, I know I would definitely to go higher on the lift and do some trim work.
6'' BDS Suspension w/ Fox 2.0 rear shocks, Bilstein 5100 adjustable front struts, 17'' XD Addict wheels, 37x12.5R17 Mickey Thompson Deegan 38s, Diablosport inTune, K&N 77 Series intake, Flowmaster 10 Series SIDO, Mag-Hytec diff cover, Rumble Bee hood, one piece aluminum grill, Extang Trifecta.
Old 10-29-2013, 01:47 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I don't think you're going to fit a 12" wide rim with only 6" of lift let alone a 15.5" wide tire. You will need the 3" body lift no question to even think about that set up. But even at that it's going to be a tight squeeze. I would much sooner recommend going with a 20x10 rim with a 38x13.5. Especially on a 1500.... The weight of a 20x12 and 38x15.5 will bog down your hemi so much you'll think you're barely moving. Plus it's 10 times harder on CV shafts and front end parts.
4x4, advice, lifted, offset, ram 1500
