Old 10-25-2013, 09:12 PM
dvarn's Avatar
dvarn dvarn is offline
Vehicle: 2009 Dodge Ram 4x4 QC
Color: Stone White
Rep:187
dvarn has a spectacular aura aboutdvarn has a spectacular aura about
Default Headlights won't turn off
This issue has just started happening. I always turn off the lights first and then the ignition. But now, the headlights stay on for approx 20-30 mins. I've checked the menu options on the console and I have "no delay" for the headlights checked like I always have.
Any thoughts on what could be causing this? Could it be a bad headlight switch?
I have Philips Xenon bulbs in all the lights with a full wiring harness and have never had any problems. And the taillights and amber lights in front turn off without a problem, only the headlights are staying on.
Old 10-25-2013, 09:41 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Sounds like an issue with your TIPM. You may want to take it to the dealer and have them flash the computer.
Old 10-26-2013, 11:44 AM
Asur Asur is offline
Vehicle: .
Rep:4371
+1 on the TIPM module
Old 10-26-2013, 06:33 PM
dvarn's Avatar
Color: Stone White
Rep:187
Thanks guys. I guess I'm looking at a new computer
Old 10-30-2013, 12:21 PM
dvarn's Avatar
Color: Stone White
Rep:187
Took it to the dealer. The technician said it was a problem with the headlight relay sticking on. He said if it does it again I can flick it and hear a click as it shuts off. Only had to pay for an hour of labor, sure better than a new TIPM! Also had the pinion nut recall done while it was there.
Old 10-30-2013, 12:37 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Glad you got it fixed!
I would of checked if power was feeding the wiring harness relay first to see if you had a bad harness relay.
Then I would of looked at the headlight relay. Then the headlight switch.
Thanks for posting you got it fixed.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-30-2013, 01:54 PM
God Bless Texas!
Rep:2929
Voonderbar! Thanks for the update.
