Old 10-25-2013, 05:27 AM
11SportCrew's Avatar
11SportCrew 11SportCrew is offline
Vehicle: 2011 Sport CrewCab
11SportCrew is on a distinguished road
Default Wire/Plug in storage box under rear seat in Crew Cab?
Sorry if this has been answered, but searching for 'plug' 'plug seat' 'plug under seat' etc didn't turn anything up.
To my suprise, I discovered my Crew Cab has handy storage bins under the rear seats. In discovering this, I also discovered a set of wires and a bare white plug in the passenger side bin.
Any clue what this goes to? I'd assume something in the rear of the truck but can't figure it out.
Thanks in advance!
Old 10-25-2013, 08:06 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Can you post some pics so that we know exactly what you're referring to?
I hate to be rude, but .....
Exco
Bill
Old 10-25-2013, 08:51 AM
Iqudayo's Avatar
Iqudayo Iqudayo is offline
Color: Mineral Gray Metallic
Rep:563
I agree with Excoastie we need pics.
hasn't anyone learned yet OMG !!!!
Old 10-25-2013, 09:42 AM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
If it is under the passanger side of the rear seat it may be for a factory subwoofer.
Old 10-25-2013, 09:14 PM
Excellent point, I figured it was a common thing so someone would know right away just from my description. Here are a couple of pics I snagged earlier.
In the overhead pic, the seat back is at the bottom of the pic, front of the truck towards the top. It's in the compartment under the passenger rear seat.
20131025_183426 by tecmotimes, on Flickr
20131025_183341 by tecmotimes, on Flickr
Thanks!
Old 10-26-2013, 07:56 AM
Excoastie's Avatar
Rep:1358
I'm guessing that it's associated with the sub woofer that you don't have installed under the rear passenger side seat.
If you had the sub, you'd have a huge black contraption with a little bitty sub, all plugged into that mystery connector.
Hope this helps
Exco
Bill
Old 10-26-2013, 08:09 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
If the plug has 4 wires, it may be for the Sub-Woofer and should be found under the passenger side rear seat.
My 2013 Sub-Woofer wire colors are
DG-WT Negitive
GY-WT Positive
DG-BR Negative
GY-BR Positive
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-26-2013, 12:31 PM
Hope this helps
Exco
It does help, and from what I found online after searching the quality doesn't justify losing the rear storage space. I'm not sure what Chrysler expected pointing a tiny sub directly upwards into the bottom of a seat full of padding.
As for me I'll just tie that cable up next time I'm back there and keep using it as jumper cable storage
