United Radio
Old 11-18-2013, 03:57 PM
gregbaker1979's Avatar
gregbaker1979 gregbaker1979 is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Two-Tone White
gregbaker1979 is on a distinguished road
Default Got it fixed
I took my truck in today, and it was the clamp issue with the exhaust that was causing the noise. They said there is a bulletin out regarding this issue, but isn't a full blown recall.
Old 11-19-2013, 11:12 AM
Tom-G Tom-G is offline
Vehicle: 2013 RAM CC 4X4
Color: Blue
Tom-G is on a distinguished road
Is the hook that needs to be bent somewhat hidden? Is it on the driver's side, passenger side, etc? I'm probably just not looking in the correct location. Thanks.
Old 11-19-2013, 11:41 AM
2010x3.92 2010x3.92 is offline
Vehicle: 2010 Ram 1500
Color: Inferno Red
Rep:32
2010x3.92 is on a distinguished road
More info please . The noise at 1600 rpm in my truck sounds like exhaust. I found a rattle at the forward clamp via a rubber mallet. I adjusted slightly and it seemed to have stopped the rattle with the mallet while under the truck but the noise while driving is still present.
Drives me bat shit crazy.
Old 11-21-2013, 12:04 PM
Color: Blue
Just giving this a bump.
Can anyone provide the TSB number or additional information on the exact location of the hook that is causing the problem? Thanks.
Old 11-21-2013, 05:21 PM
Ram Dave's Avatar
Ram Dave Ram Dave is offline
Vehicle: 2013 ram 1500 crew cab
Trim Level: Big horn
Color: Deep cherry red
Ram Dave is on a distinguished road
my hemi ram has a bit of a rattle when you get on it a bit.sounds to me like it is coming from the engine.it's not bad sounding,i just thought it was a normal noise
Old 11-21-2013, 09:17 PM
I'm the worst person to talk about truck mechanics, as any time I try to fix something I usually make things worse. So to explain what they did to fix it, I can't. I printed off this thread and gave it to the service technician. After the service he said the problem was the described exhaust hook/clamp issue in this thread. He said there's even a Technical Service Bulletin regarding this issue. I didn't ask for any details as he would be speaking a foreign language to me. If you can't find it yourself I would recommend taking this thread to your dealer, and they should be able to fix it.
Old 11-22-2013, 09:28 AM
Color: Inferno Red
Rep:32
If you could email them to hook you up with the TSB that would be awesome.
Old 11-23-2013, 09:49 PM
Color: Blue
Had my 1500 into the dealer for another issue. While it was on the lift both the tech and I checked over the exhaust system. No hooks. My truck was built in June so maybe the hook is only on trucks built earlier (just guessing).
Still have the engine vibration at 1800 - 2000 RPMs. The techs can't figure out what is causing it. Frustrating!
Old 11-30-2013, 11:58 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Do any of you guys have a pic of where this hook/clamp is? I am not able to look at my truck right now, but I have the same sound on mine. Thanks!
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 12-04-2013, 10:56 PM
Gonefishn1212 Gonefishn1212 is offline
Vehicle: 2013 RAM 1500
Trim Level: Laramie hemi/8sp/air
Color: Black two tone
Rep:37
Gonefishn1212 is on a distinguished road
took mine to the dealership, they told me first that they tightened the right rear bolt on my side step. I said ok and didn't make off the lot befor I heard the same rattle, I took a service manager for a ride/ we both heard the rattle, he then take the tecnitian for a ride and then I was told its normal.....its drive line torque. yea F U im not that dumb, and I left
acceleration, acceleration noise, noise
