Old 10-24-2013, 10:47 PM
gregbaker1979's Avatar
gregbaker1979 gregbaker1979 is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Two-Tone White
gregbaker1979 is on a distinguished road
Default Noise while Accelerating
I hear a strange rattling noise only when I accelerate in drive. This is my first HEMI, so I wasn't sure if it was a normal "HEMI" sound. It's hard to tell where the noise is coming from, but I would guess either engine, transmission, or exhaust. It does it every time I drive, and it does it when my RPM's are higher. Does anyone experience this or know what I'm referring to?
Thanks in advance!
Old 11-05-2013, 04:22 PM
CHAT2TRISTAN's Avatar
CHAT2TRISTAN CHAT2TRISTAN is offline
Vehicle: 2013 RAM 1500 SPORT
Trim Level: SPORT
Color: BLACK
Rep:13
CHAT2TRISTAN is on a distinguished road
You have a HEMI... its just all the power being unleashed! But in all seriousness I have an interior plastic rattle when accelerating and/or at higher revs. It seems like there is a sweet spot in the RPM where it does it and then it stops. I also have a S&B cold air intake which made it worse. More air=more power especially when the temperature drops.
If you can't Dodge em RAM em!
Old 11-05-2013, 04:31 PM
LS1EB's Avatar
LS1EB LS1EB is offline
Vehicle: 2013 Ram 1500 QC 4X4
Color: Copperhead Pearl
Rep:54
LS1EB will become famous soon enough
I have the same thing at higher RPMs. I have no clue what it is but I am assuming it is just a resonance. I'd just keep an ear on it and if it gets worse take it in.
2013 QC Express 4x4 Hemi, Copperhead Pearl, painted tails & 3rd, black badges & wheels, 20% tint.
Old 11-05-2013, 07:26 PM
2011 ASSAULT 800's Avatar
Trim Level: Quad Cab Sport
Rep:251
I have interior rattles but I also have an exhaust leak type sound when accelerating, not sure if it is an exhaust leak, the infamous dodge cracked manifold or just normal noise, the dealer will be looming at it when I take my truck there soon.
Old 11-06-2013, 08:49 PM
deathwarden5 deathwarden5 is offline
Vehicle: 2014 Ram 1500 Sport CC
Trim Level: Crew Sport
Rep:26
deathwarden5 is on a distinguished road
I have a rattle/buzzing/screech sound on my '14, also had it on my '13. It's 2500RPM+, louder as the revs increase, and loudest during shifts.
I found on another forum, people were having the same problem. What someone found, was about the clamp where the downpipes meet the exhaust, there is a little metal hook/bracket thing (looks like it was only used for assembly). Once that was bent up out of the way, the rattle was gone.
I've yet to do it on mine, just been too lazy to put it on the hoist.
Old 11-09-2013, 03:20 AM
Burner Burner is offline
Vehicle: 2013 1500 Laramie
Color: Black/grey two tone
Rep:19
Burner is on a distinguished road
deathwarden5 - I had the exact same problem with my exhaust and took it the dealer 3 times, each time they tried replacing parts on the exhaust and didn't solve the problem until a mechanic finally noticed that (metal hook you mentioned), it was just to close to the exhaust pipe and at high rpms it would vibrate and rub on the exhaust. Its a simple fix once you know were that noise is coming from.
Old 11-09-2013, 09:11 AM
Hemi13's Avatar
Hemi13 Hemi13 is offline
Vehicle: 2013 Ram Laramie
Rep:89
Hemi13 will become famous soon enough
This is great to know ! Thanks. I don't have tea rattle but u never knnow
2013 Laramie, Hemi, 6spd, 3.55, silver, push button/keyless start, sunroof, nav etc
Old 11-09-2013, 09:36 AM
Ford Killa Ford Killa is offline
Vehicle: 2011 Dodge Ram 1500 LONE STAR
Color: Silver Metallic
Ford Killa is on a distinguished road
I think i have that i will be checking that today it drives me crazy.
Old 11-09-2013, 10:58 AM
2010x3.92 2010x3.92 is offline
Vehicle: 2010 Ram 1500
Color: Inferno Red
Rep:32
2010x3.92 is on a distinguished road
Ever since my truck had about 25k on it the thing has had this odd little rattle/resonance (sounds like exhaust) if it operates at 1600 rpms under light acceleration. It will make the noise as it passes the rpm if you accelerate a bit more briskly but after a certain throttle input point I think it passes the rpm too quickly to produce the symptom. It's a very hard noise to pinpoint because its one of those things when you sit in various parts of the cab it makes it seem as if the position of which the noise seems to originate changes. It sounds very much like a loose catalyst in a converter but I can't reproduce any type of noise in the exhaust system. I really hope it ends up being the cat so it will be covered over the 8/80 federal emissions warranty.
Old 11-13-2013, 10:39 PM
Thank you all for the info. I have an appointment Monday to have it looked at. Hopefully it's the exhaust hook issue. I'll keep you posted.
acceleration, acceleration noise, noise
