United Radio
Old 10-26-2013, 09:33 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I have seen a couple trucks come from the factory with a goofy lean to one side or the other like yours has, it is not very noticeable at stock height but once you lift the truck it is very noticeable, there have been a few other members here that have had similar issues when lifting there truck (not just RCX specific either), I do not remember what they did to get it fixed I will search the boards for a bit with the search feature and see if I can fine them.
Thanks
Jeremiah
Old 10-26-2013, 06:19 PM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
If what Jeremiah is saying is true with your truck, maybe you could set the driver bilstein to 1.4 or 2.1 to compensate. Not sure if you could actually do that without screwing up your front end geometry. But then again it's messed up already?...maybe worth a shot
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched -CST/Pro Comp 6" Lift - 35x12.50 ATZ P3 and 20x9 +1mm Fuel Mavericks -AMP Power Steps -8k HID -HEMIFEVER Tune
Old 10-28-2013, 08:41 PM
4X4JUNKIE's Avatar
4X4JUNKIE 4X4JUNKIE is offline
Vehicle: 2007 Ram 1500 Sport Quad cab
Rep:34
4X4JUNKIE is on a distinguished road
Thanks
Jeremiah
Thanks man, I appreciate the help!
RCX 6 inch lift, 20x9 Fuel Hostages, 35x13.5 Fuel Mud Grippers, Magnaflow exhaust, 20% tint, CAI.
Old 10-29-2013, 08:12 AM
Vehicle: 2012 Dodge Ram CC 4X4
Color: PX8 Black
Our trucks have a 'dodge lean'
Typically it's the rear that lean to the left rather than the entire truck.
This is due to the gas tank and amount of fuel in it.
The way to correct this is to throw a different coil spacer on that side. Either 1/2" if you're running nothing...or 1/2" more than what you have on the passenger side.
I have a 1.5" on my rear drivers and 1" on my passenger rear.
Lean is now gone.
I had a 1/2"
Some have a 3/4" lean. So measure first before grabbing the rear coil spacer
2014 Ram Hemi Tuning now available from Diablo Sport get yours today!
Old 01-09-2014, 07:24 PM
Rammit08's Avatar
Rammit08 Rammit08 is offline
Vehicle: 2008 dodge ram 1500
Trim Level: Sxt
Color: Grey
Rammit08 is on a distinguished road
Hey guys new to the forum, I just installed a 6 inch rcx. On my 08 I'm having the same problem I'm getting 1 1/2 inch difference between drivers and passengers I figured it could have a lot to do with the front end but I installed quick struts less than a year ago. Thinking of trying the bilstein ride height adjustable's and new coils and seeing how those work.
Old 01-09-2014, 08:58 PM
2006ramhemi's Avatar
2006ramhemi 2006ramhemi is offline
Vehicle: 2006 Dodge Ram
Color: Gray
Rep:50
2006ramhemi will become famous soon enough
Originally Posted by 4X4JUNKIE View Post
already checked the bilsteins, they are both at the same height. Could a bad alignment cause this? I do notice the truck pulling slightly to the right. And if I want to go down the road straight, I have to hold the wheel slightly to the right.
i think the pulling is the tires. i have an 06 ram with 6" rcx and with stock wheels and tires it was fine. after the new wheels and tires it started pulling to the right. the shop i go to that lifts trucks all the time says the bigger tires grip the road better and because of road crown it goes to the right. drive on the left side of the road ( when no one is around obviously ) and it should pull to the left. thats what mine does
Old 01-09-2014, 11:21 PM
RAM357's Avatar
RAM357 RAM357 is offline
R A M M S T E I N
Vehicle: 2014 RAM 1500 Sport CC Hemi
Trim Level: Sportabulous
Rep:580
RAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to allRAM357 is a name known to all
Different truck all together, but when I initially put an Australian Old Man Emu lift in my other 4x4, it did what yours is doing.
Turned out the Aussies have the coils flipped around to account for a different weight distribution than the North American version of the same 4x4. Once I flipped the coils left to right, everything sat great.
*YES IT'S BLACK AND WHITE AND YES IT'S A SEXY THANG*
* 2014 RAM Sport CC* BDS 6" Suspension* Fox 2.5 Coil-over front * Fox 2.0 rear & Pro-Ride 3" coil* 3.92 Gearing* Fuel hostages in 20x9 +1
37x12.5R20 Pro Comp Xtreme MT2
* Diablo Sport Trinity T1000 * Cabin Air Filter
* ARH LT headers * Magnaflow catback/5" tips * 87mm Ported TB * Moroso Polished Catch Can*_QTP_electric_cutout_&_3"_turn_down * Legmaker Short Ram * S&B custom filter * Outerwears Pre-filter * Extang Solid-Fold Tonneau
Old 01-09-2014, 11:32 PM
Selcher's Avatar
Selcher Selcher is offline
Trim Level: Sport Club Cab 4x4
Selcher is on a distinguished road
Ha! And their toilets flush backwards too... I dunno, there's some kind of Aussie joke in that fix of your's somewhere... lol
MBRP Pro Series Cat Back Exhaust
Superchips Flashpaq 3865
Old 01-18-2014, 03:30 PM
Pimppapa1977's Avatar
Pimppapa1977 Pimppapa1977 is offline
Vehicle: 2007 RAM
Color: Grey
Rep:16
Pimppapa1977 is on a distinguished road
I am about to have my RCX 6" installed in a few wks. Please let us know if you find anything. Good Luck!!!
