Old 10-23-2013, 09:31 PM
dauer53's Avatar
dauer53 dauer53 is offline
Vehicle: 2011 1500 Quad Cab Sport 4x4
dauer53 is on a distinguished road
Default Tailgate Help Please
For the second year in a row now when it starts getting cold outside my tailgate latch doesn't want to work. It'll open just fine but it wont latch when I close it until I wiggle the one side free. Is it possible the grease is freezing? Any suggestions? Big pain when I'm in a rush in the mornings.
Old 10-24-2013, 02:32 AM
MoldyTaco's Avatar
MoldyTaco MoldyTaco is offline
Vehicle: 2005 Dodge Ram 1500 Quad Cab
Trim Level: SLT Big Horn Edition
Rep:27
MoldyTaco is on a distinguished road
I personally would try either some white lithium grease or graphite. In my experience they seem to handle cold weather better. Also check to see if anything is stuck in there like sap. In the summer the sap stays thinner and hardens as the temperature drops. Had that happen to me on a trailer latch once.
" There is a reason we are born with brains in our heads, not rocks!"
Old 10-24-2013, 02:41 AM
Rep:2640
there is an answer on the internet, i recall it has something to do with a certain kind of lubricant, it does not freeze in colder climates
Old 10-24-2013, 08:34 AM
Asur Asur is offline
Vehicle: .
Rep:4371
As the others have said Lithium lubricant is your best bet, WD40 has just released a new Lithium based Lubricant in there specialist products, its perfect for door latches, locks and other areas like this. Its much lighter than regular lithium grease but keeps things loose in cold weather, you will need to clean your latches then apply liberally on the latch itself. Hope this helps.
http://www.wd40specialist.com/products
Old 10-26-2013, 03:01 PM
dauer53's Avatar
Thanks for the help all... When I looked at the springs they were COVERED with dirt and what not. Cleaned those off and hit them with regular WD-40(already had some) and it's back to working like a charm. I never thought with those being that recessed they would've gotten that dirty but they were gross.
Old 10-26-2013, 03:24 PM
Rep:2640
i think you will discover that the WD-40 attracts dirt quicker
WD stands for water displacement
__________________________________________________ _______
you could try
FOOD GRADE SILICONE or FOOD GRADE MINERAL OIL
or
3M 08897 Silicone Lubricant (Dry Type) - 8.5 oz.
"High quality silicone lubricant which eliminates rubber squeaks, prevents sticking and seals out moisture"
This product contains no petroleum oils to stain fabrics and will not freeze at -28 degrees F nor degrade at +350 degrees F
Most Lithium grease is only good to -5 F
Old 10-28-2013, 12:25 PM
mattl22's Avatar
mattl22 mattl22 is offline
Vehicle: 2011 Ram 1500 Sport QC
mattl22 is on a distinguished road
you could try
or
Agree! WD is a quick fix but something else, like the silicone, will give you a longer lasting fix.
Old 10-29-2013, 02:19 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
i would just keep an eye on it for now and see if accumulates dirt.
