Old 10-23-2013, 07:15 PM
Stewman Stewman is offline
Trim Level: Outdoorsman
Color: Black/Grey
Rep:15
Stewman is on a distinguished road
Default Problems sealing headlights
Hey all, I have tried sealing my headlights 3 times now after my retrofit with the Butyl rubber sealant and STILL have condensation getting in. I have siliconed up the OEM caps, OEM bulb gaskets, and the HID boot and wiring going through it. Same problem with the foglights.
I also ran a bead of silicone around the entire outside joint of the headlights.
Any suggestions?
Thank you, a very frustrated retrofitter
Old 10-23-2013, 08:08 PM
Asur Asur is offline
Vehicle: .
Rep:4371
At the top of the headlight there are 2 holes, they have a black paper on top of them, these are to let moisture out and none in, are they still there?, if these are pierced they will let moisture in, you can flash a light behind them you will see the light go through but very faintly then they are good. I build my own set, about 3 months in they started to let moisture in, I checked them and found that the cheap rubber gasket that came with the Chinese headlamps that is installed between the bulb or "projector unit" with the heat cracked and was letting moisture in there (cheap cheap cheap sheet) So on a dry day, I pulled them off and let them dry out, then replaced them with some OEM one's, never had an issue after that.
Old 10-23-2013, 09:48 PM
I push the skinny pedal
Rep:3277
I also filled the 2 'vent' holes on the back with silicone to prevent any moisture from getting in as well. I went for the no moisture in/no moisture out scorched earth policy.
Kurtis
Old 10-25-2013, 12:00 AM
Color: Black/Grey
Rep:15
Hmm ok, so you guys recommend plugging the breather holes? I just scraped off the silicone (it never really adhered to the black casing) and used some spray rubber and went over the entire seam with it. Hopefully this helps.
Should I plug the vents as well?
Old 10-25-2013, 01:15 AM
Color: Black/Grey
Rep:15
Re-sealed the foglights with butyl tape. Checked for a perfect seal by dipping into water, no leaks. Turned them on tonight and withing 3 minutes they had almost completely fogged up. The bulb had been surrounded with silicone so no gaps on that end.
Is butyl tape only good in the desert? It's almost like it promotes condensation...
Old 10-26-2013, 10:18 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
If you plugged the vents there is condensation in the air (humidity). Put lights in the oven with out the bulbs at 250 deg. for 10-15 minutes so you get the moisture out. Then put the bulbs in right away. That should take of the moisture.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
