Old 10-24-2013, 07:39 AM
Bowsprit
Question Winter tire question
2013 Ram 4x4 with air suspension. I need to buy winter tires and rims. 90% of my winter driving is highway, Canada near Ottawa. Trying to decide on rim/tire sizes. What are the effects of 20 inch vs 18 inch etc. Gas mileage, traction, handling?
Old 10-24-2013, 01:46 PM
Cush09 Cush09 is offline
Vehicle: 2013 Dodge Ram
Cush09 is on a distinguished road
Originally Posted by Rockyd831 View Post
This is my truck with a:
2.5/1.5 Level
35*12.5*20 Tires with XD Addict Wheels
They are a -12mm offset so stick out farther then the fender
With the flares it looks complete
Did you just use spacers or did you replace the shocks?
Old 10-24-2013, 03:02 PM
Rexer's Avatar
Rexer Rexer is offline
Vehicle: Ram 1500
Rep:207
Rexer has a spectacular aura aboutRexer has a spectacular aura aboutRexer has a spectacular aura about
Originally Posted by dawoodsman View Post
Grain shovel tossed in the back. Some bags of sand or kitty litter. Hi-lift jack with a mount to keep it from sliding all over in the bed. Winch (if you have trees to use them). I'd ditch the fat 20" idea if it were mine--tall and narrow is better if you really are riding off road in snow. The outdoorsman's run narrower tires that are just a bit shorter than the stock 20's these days for a reason--better off road capability.
The low front air dam on the outdoorsman doesn't stick down as far either. I wonder if that's a direct swap with any dodge--the stock one on non-outdoorsmans is really going to plow snow if gets deep enough, I think.
I am having a fit issue with them--still working it out with the manufacturer--but I bought some of the new aries aluminum step bars. Big beefy bars in a textured black finish, will never rust. I see a lot of rusty bars and runnning boards around here.
I wouldn't buy them for any truck that has wheel flares yet though, it appears their mount system did not consider that the bar would bump into the flare if adjusting up at all on the mount. If you add flares to your truck, make sure you consider what they will do to any step bar or running board install.
That's some good winter advice is I've seen it! All seasons are ok if your going through plowed roads all the time, but if your going to be running thru deep snow then you want real winter tires...tall and narrow do give the best traction in the winter!
Old 10-25-2013, 08:18 PM
Rockyd831's Avatar
Rockyd831 Rockyd831 is offline
Vehicle: 2013 Dodge Ram 1500 Sport
Rep:33
Rockyd831 is on a distinguished road
Spacers
Was done at the dealer
I went to Capital DOdge in the Southside
2013 Ram 1500 CC - Silver Grey Metallic,2.5" Level,OEM Fender Flares
More to come.....
Old 10-27-2013, 07:05 PM
Irv's Avatar
Irv Irv is offline
Vehicle: White 2013 QC 4x4 BigHorn
Trim Level: BigHorn
Rep:14
Irv is on a distinguished road
I am also looking for a set of winter rims/tires but I am having a difficult time finding a set.
Was thinking about a 17" inch rim and tire combo but was told it will be about 3-4 Km difference on the speedo/odometer.
Was thinking about some 20" wheels but those tires are expensive!
Was also told just to run my current rim/tire combo but I don't want to ruin the chrome cladded rims.
But was told they are very durable and it won't be a problem running them in the snow/salt/slush/sh*t, but not sure I want to take the chance?
2013, oilfield, sport, tires, winter
