Old 10-23-2013, 01:56 PM
jorge1985's Avatar
jorge1985 jorge1985 is offline
Vehicle: 2014 Ram 1500
jorge1985 is on a distinguished road
Default Tires on stock wheels
I was wondering what would be the biggest size tire you can out on the stock wheels without spacers or rubbing? Or maybe a good set up on the stock wheels?
Old 10-23-2013, 02:06 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
285 is typically the widest you can go on stock tires with no spacers or rubbing. Some guys have managed to go wider but it's uncommon.
As far as height goes, that depends if you're at stock height or leveled... At stock height I wouldn't go much bigger than a 33" but you can probably fit a 33.5". If you're leveled you can fit up to 35" tall but I'd recommend staying closer to 34" to avoid looking stuffed. That partially depends on the type of tire you're going with too though.
Old 10-23-2013, 02:07 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
typically 285 is as wide as you can go.
some guys have been able to fit larger. ive even seen guys squeeze full 35s on. it looks crammed. it also depends on much rubbing ur willing to put up with. A minor rub at full lock is easy to avoid.
also, my whole family is from St. Augustine. I'm a Ponce, i'm sure you've seen the name around.
good luck on your tire search!
Old 10-24-2013, 07:11 AM
jorge1985's Avatar
My truck is stock with no level or anything. Thanks for the info very informative. I wanted to put some 35's on but I don't think I can deal with any rubbing plus I like the stock height and look but need some bigger tires so 33's. And I'm very familiar with the Ponce name not only because I live in St. Augustine but also that name is everywhere in Puerto Rico where I'm from
