Old 10-22-2013, 11:52 PM
OrangeRam's Avatar
OrangeRam OrangeRam is offline
Vehicle: 2008 Dodge Ram
Color: Burnt Orange
OrangeRam is on a distinguished road
Default Looking for a good leveling kit.
Ok so I'm wanting to level my 2008 Ram 1500 4.7L RWD Truck. I have heard both about the spacers and the adjustable suspension. Will someone please help me find what I really want. Want my truck to be level (bring the front end up). thanks in advance.
2008 Dodge Ram 1500 4X2 4.7L V8
Old 10-23-2013, 03:36 AM
northern2002's Avatar
northern2002 northern2002 is offline
Vehicle: 2002 dodge ram 2500
Trim Level: SLT plus
Color: gray
northern2002 is on a distinguished road
Take a measurment at the wheel wells front and back to start the differance between the two will give the number you will need to level the truck.if you plan on towing with the truck get the adjustable, if not just get spacers installed up front and if later you decide to tow you can always get a set of overload springs for the back or airbags.i dont recomend air bags due to the fack they are rubber and will need to be replaced due to wheathering over time similar to tires.
Old 10-23-2013, 09:28 AM
OrangeRam's Avatar
Color: Burnt Orange
Default ok, another question>?
Ok so I have another question then, as far as the adjustable ones, is it just for the front or do I need all four shocks to be adjustable? thanks
Old 10-23-2013, 09:47 AM
Asur Asur is offline
Vehicle: .
Rep:4371
Its always best to have 4 of the same manufactures shocks on your truck but I Leveled my truck with Bilstiens adjustables set at 2.1 and I am now 1/2in lower in the front than the rear, The Bilstiens 5100 i used are specific for 4x4.
Old 10-23-2013, 10:00 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I assume since you said RWD that means you are 2wd only.
i only ever see polyurethane spacers for 2wd trucks. personally not a fan but I think it's your only choice.
you can try to google around for steel spacers.
Old 10-23-2013, 10:49 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Poly spacers don't make as much noise as the steel ones though
Old 10-23-2013, 11:16 AM
Rep:1900
I suppose. I had poly spacers on my 2wd f150 and after 8 months you couldn't even tell it was leveled anymore.
Maybe they work better on the rams. not sure, don't see many people running them. A lot of people get on here asking how to level their 2wds, then I never see any follow up.
Old 10-23-2013, 12:00 PM
OrangeRam's Avatar
Color: Burnt Orange
Yeah thats pretty much all im seeing for the 2WD, maybe I should just get a lift instead, any thoughts
Old 10-23-2013, 12:02 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
It really depends on what you want. Look deep inside yourself and ask the question, 'what will make me the happiest?'
Old 10-23-2013, 12:34 PM
OrangeRam's Avatar
Color: Burnt Orange
Lol, I don't have that kinda money right now, just not sure, guess I gotta a lot more research to do
