Old 10-22-2013, 10:03 PM
Whiplash's Avatar
Whiplash Whiplash is offline
Vehicle: 2013 1500 SLT Big Horn 4x4
Color: Black Gold
Rep:177
Whiplash has a spectacular aura aboutWhiplash has a spectacular aura about
Default how much juice...
to trip a relay?
i just got my blue sea fuse block that i'm basically using for switch power. Just wanna make sure i can use 18ga (bundled, color coded) for easy wire runs. This will run to switches (from OTRATTW) which will be used to trigger relays (30 or 40a depending on requirements) powered straight from battery to lights etc.
Am i good with 18ga wire and say 5a fuses? or will i be pushing more current that will require larger wire/higher fusing
thanx!!
MODS: Magnaflow 16869 cat-back - S&B CAI - BakFlipG2 - Bilstein 5100s F/B - AirLift 1000 - BackRack - FT-857D/ATAS-120
next: Rims 'n rubber - That'll be it, too many electrical risks involved to go furthur
Old 10-22-2013, 10:09 PM
Kindanocturnal's Avatar
Kindanocturnal Kindanocturnal is offline
Color: Black/sandstone
Rep:38
Kindanocturnal is on a distinguished road
18 gauge is fine if you are only running 5 amps. You should be good up to 20 amps. If you are running multiple 5 amp circuits your power feeder wire will likely need to be increased.
Old 10-22-2013, 10:25 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
the power and ground from battery to block is 8ga...
i'll be tapping off directly at the tie-in points for my ham radio (otherwise i'd just be running 14 ), everything else will run thru the block
thanx Kindanocturnal
Old 10-23-2013, 11:41 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Originally Posted by Whiplash View Post
to trip a relay?
thanx!!
If you are only using the 18ga wire to trip the relay through terminals 85 and 86 on the relay, from the switch, you will be good to go. The 5 amp fuse will be enough to also have a lighted switch.
Larger gauge wire and fuses are needed to power your accessory using terminals 30, 87, and 87A depending on how you wire the relay.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-23-2013, 01:07 PM
Whiplash's Avatar
Color: Black Gold
Rep:177
thanx Greg. Yes, i'll be using minimum 14 from the relay to acc, or thicker if the instructions call for it I think i have a 500' roll of 12 somewhere in the garage
