Old 10-22-2013, 06:58 PM
express2012 express2012 is offline
Vehicle: 2012 RAM 1500 4X4 QUAD CAB
Trim Level: EXPRESS
Color: RED
Rep:45
express2012 is on a distinguished road
Default want to put 295/65/20 on stock 20x9 chrome clads need advice
I would like to put a 35" tire on my ram I have 20x9 chrome clads the nitto grappler 295/65/20 is the tire i would like to go with it measurse 35.4x12.13 on a 8.5 wheel i really like my factory wheel which along with the cost is stopping me from going tire/wheel set up with different offset. rcx offers a 1/4" wheel spacer which the swear up and down they can get a 35x12.50x20 on factory wheel with level (which i have) and have no vibration, loosening up issues. my question is has anyone fitted these without spacers or have used spacers had or had no issues i appreciatte any feed back thanks
Old 10-22-2013, 08:02 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
You'll have rub at full lock. 1/4" spacer eliminates it or just don't quite go to full lock.
Simon
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I think you'll need spacers. At least on my truck, the stock size barely clears the rear fender liners. You can actually see rub marks and when I drive in mud then it freezes on the tires, the mud will make a racket till it falls off. I do run 6 mm spacers on the front of my RT Magnum with 275/40/20's and have had no problem, if you end up with spacers, just keep the lug nuts torqued, check em a couple times after fist driving with them. Like you, I really like the 20" CC's, still look new.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 10-22-2013, 09:14 PM
Goatah's Avatar
Goatah Goatah is offline
Vehicle: 2012 Ram 1500
Goatah is on a distinguished road
You should be good to go with the .250 spacer. Also, take a heat gun to the fender lump and hold it in until it sets and that gets rid of the rubbing issue.
2" Level - 295/65R20 Toyo ATII Xtreme - Flowmaster Super 40 - AFE Stage II Intake - Diablo DCX1000
Old 10-22-2013, 09:55 PM
Trim Level: EXPRESS
Color: RED
Rep:45
thanks anty other info appreciated may come down to just trying and updating i see a lot of threads on this issue
Old 10-23-2013, 10:01 PM
casper97ta's Avatar
casper97ta casper97ta is offline
Vehicle: 2009 Ram Crew Cab
Rep:27
casper97ta is on a distinguished road
I ran those exact tires on my leveled 05 on the stock chrome 20's with no issues or rubbing at all. I do believe the 4th Gen's have less clearance between the back of the tire and the upper A-arm though. I ran with a 2" wheel spacer and without any spacer at all. Just to be on the safe side you could just run the 1/4" spacer to be sure you have no rubbing at all.
Let me see if I can find some pics of my 05 with those tires on it.
Edit: here are some pics with and with out the spacers
Mods
6" RCX - Bilsteins @ 2.1 - 1" TGC rear spacer - 37x13.5x20 Amp Terrains on Stock chrome - Superchips 3865 on 93 with trans tune - Vararam - Bully's 87mm TB - Magnaflow 14" - DeeZee Tailgate Assist - Bakflip G2- Debadged - 2500 Pocket flares - Cabin Filter - 2 12" Sundowns in Foxbox
Old 10-26-2013, 08:53 PM
Trim Level: EXPRESS
Color: RED
Rep:45
thanks i put on a spacer 1/4" seems fine there is enough clearance now im sure going to run awhile till i get the bigger tires
Old 11-01-2013, 07:44 PM
Trim Level: EXPRESS
Color: RED
Rep:45
took spacers off rear wheel would not center started vibrating ordered hubcentric 3/8" (10mm) spacers from motorsport tech more money but he was very familiar with the dodge great company 180.00 plus shipping for 4 will update
