View Poll Results: Borla install, Weld-in or Clamp
Weld 2 100.00%
Clamp 0 0%
Voters: 2. You may not vote on this poll
Old 10-22-2013, 07:18 AM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:33
theGSE10 is on a distinguished road
Default Borla install...weld-in or clamps?
So my truck goes into the shop this afternoon to have my new oval Borla XR1 installed but I am torn between getting it welded in or having the clamp in like stock. Opinions?
Hellwig Sway Bar, Green filter, Borla XR-1, Line-X, Bak RollX, JBA TCC Shorty's, Raptor 4" nerf, Hunter Bull Bar, 20" Cree LB, Moroso Catch Can, Bilsteins @ 2.8, Fox 2.0 rear, TGC 1.75 spacer, Air Lift 1000, Bak Box 2, Trinity T1000
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
Old 10-22-2013, 09:15 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
id always go welded. pretty much ensures no exhaust leaks.
Old 10-22-2013, 01:09 PM
theGSE10's Avatar
Rep:33
That's what the fabricator told me too. He also said it'd be cheaper because it would save him time. I guess I just needed some reassurance
Do you know what a good going rate for work like this is? He quoted me between $150-200 for welding in the muffler, 6" long stainless steel extension pipe, and y-pipe to fit back into the stock duals. Does that sound reasonable?
Old 10-22-2013, 01:57 PM
Rep:2620
Fabricator/welder labor rates are $50 per hour or more, as of 1 1/2 years ago
shop rates are of course higher
welding is the only way to go, unless you just want to see how it sounds, then you would want to just clamp it on temporarily
__________________________________________________ _______
While i was at a muffler shop, they told me that companies like Magnaflow have a warranty, when a customer tells a muffler shop to take one of those off because of some thing. The shop has to send the whole muffler plus a couple inches of your exhaust pipe back to Magnaflow, because they want to check the welds that held everything together
Old 10-30-2013, 01:20 AM
Trim Level: sport
Color: green
Rep:643
witha borla, weld it and forget it. lasts forever.
