Old 10-22-2013, 12:36 AM
4GoatsOnly's Avatar
4GoatsOnly 4GoatsOnly is offline
Vehicle: 2014 Lone Star Crew Cab 4x4
Trim Level: Lone Star 4x4
Rep:16
4GoatsOnly is on a distinguished road
Default 2011 Brake controller install
I'm currently using a aftermarket brake controller and plan to install a factory controller in the near future. Since the truck didn't come with it will it recognize the install.
bayougoatmounts
Old 10-22-2013, 08:25 PM
clatla's Avatar
clatla clatla is offline
Color: Snow White
Rep:31
clatla is on a distinguished road
You will need to get the option added to the build sheet for it to show in the EVIC. My truck didn't come with the factory controller. I had the dealer install when new and flash the computer. The controller failed and I installed an aftermarket one since the factory controller isn't that great. Now I cant get the code removed from the build sheet so I get an error message every time I start the truck. So consider your options before you regret it. The only nice thing about the factory controller was the fit and finish.
Old 11-08-2013, 09:59 AM
terryjones1 terryjones1 is offline
Vehicle: 2014 RAM 1500 Quad Cab
Trim Level: Tradesman-Express
terryjones1 is on a distinguished road
Originally Posted by clatla View Post
I installed an aftermarket one (brake controller) since the factory controller isn't that great. The only nice thing about the factory controller was the fit and finish.
I have a new RAM 1500.
I am planning on installing a Tekonsha Brake Controller and a wiring harness adapter.
The Tekonsha wiring harness application guide calls for P/N 3021-P.
What brand after-market controller did you purchase?
Did you use a "Plug & Play" type (2 connecters) of adapter to connect from controller to truck?
Old 11-09-2013, 07:29 PM
clatla's Avatar
Color: Snow White
Rep:31
I have a Tekonsha P3. I installed it with the tekonsha adapter. It only uses one of the factory plugs. Works great.
Old 11-10-2013, 09:12 AM
h2oman's Avatar
h2oman h2oman is online now
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:349
Tekonsha make great bc's. You shouldn't feel inadequate over the factory controller.
333Half the beast
I used to be
