Old 10-21-2013, 11:13 PM
WhiteRam2620 WhiteRam2620 is offline
Vehicle: 2011 Ram
WhiteRam2620 is on a distinguished road
Default Newbie Needs Help with LED resistors
I've begun installing LED's and have installed turn signals. I need to install the resistors and I've been told I need to wire a resistor for the turn and for the ground, is this true? Any help here would greatly be appreciated in advance.
Old 10-22-2013, 02:46 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Yes, you need to get a 50 ohm resistor and put one end on the ground wire and the other end on the turn signal hot wire.
Old 10-22-2013, 10:23 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
You need one for each led light. So 2 for the front and 2 for the rear.
Ones like this: http://www.superbrightleds.com/morei...r-kit/190/831/
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-22-2013, 11:14 AM
Vehicle: 2011 Ram
Cool so then that one from superbright will work fine then? I ask because you said a 50 ohm resistor. I can wire things but never been good with the other stuff. Thanks Again.
Old 10-23-2013, 04:57 PM
God Bless Texas!
Rep:2929
Yes, here's what mine looked like with the resistor soldered on it. I used a 5w 47ohm resistor.
