Old 10-21-2013, 07:17 PM
hutch74 hutch74 is offline
Vehicle: 2011 dodge ram 1500
hutch74 is on a distinguished road
Default Gear Oil
Was thinking of changing my gear oil in my ram 1500. I know the weight of the synthetic oil I am to use but was curious on name brand of gear oil that they would recommend and where to buy it in central alberta Canada.
Thanks
Old 10-21-2013, 07:27 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
Gear oil is the one place i wont use synthetic. Dino tends to disipate heat better IMO. If you are going to use synth use one that is a true synth. Royal Purple, Redline, Amsoil, or the like. Just for the record, i do not recomend mobil one, most will though.
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 10-21-2013, 09:44 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
+1 on PR, RedLine or Valvoline.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it harder if your stupid." How would you know?
Old 10-21-2013, 10:29 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:363
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
also if you have the lsd diff don't forget the oil additive you have to put in
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 10-22-2013, 03:32 PM
how do I know if I have the lsd diff.
Hutch74
Old 10-22-2013, 10:19 PM
cawish33 cawish33 is offline
Trim Level: sport q/c
Color: hunter green pearl
cawish33 is on a distinguished road
jack one wheel and turn by hand other wheel and it is suppose to lock,
and for the additive stuff , you don't need with royal purple , don't know on other brand
Old 10-22-2013, 10:41 PM
crusher's Avatar
Rep:363
Hutch74
look on your window stiker if you still have it
or
contact your dealer, with your vin number they will look it up in the system for you
as far as the original gear oil from chrysler it is require to had the additive
Old 10-22-2013, 10:51 PM
Hermes1 Hermes1 is offline
Vehicle: A Truck
Rep:2549
No need to add the additive with Amsoil.
Old 10-24-2013, 01:56 PM
Thanks a lot got the diff oils changed yesterday. for the 6 bucks I added the additive anyway.
So now my next question would be is when should a guy be doing a transmission and transfer case oil change.
Thanks
Hutch74
Old 11-04-2013, 05:33 PM
SuzanneClerkin SuzanneClerkin is offline
Vehicle: 2008 Dodge Ram
Trim Level: N/A
SuzanneClerkin is on a distinguished road
Hey hutch74!
We recommend using Pennzoil Synthetic Gear Oil for your Ram 1500 differential. It can be found at your nearest Canadian Tire or NAPA auto part stores. Please remember to add additional limited slip additive should your truck has a limited slip rear end.
-The Pennzoil Team
