Old 10-21-2013, 04:08 PM
idiot idiot is offline
Vehicle: 1996 dodge ram
idiot is on a distinguished road
Default Help!
Hey guys, newbie here. I have a 1996 Ram 1500 with the 5.9 360 in it. I took it off roading the other day and hit a hole that looked shallower than it actually was. Anyway, I had it in the water pretty good and got it out and it started right up. After a while, it lost pretty much all power. The engine was working but it wouldn't turn the wheels. I let it sit and it was running good enough to get me home. Now it is losing power again. Any ideas of what could be causing this? Any help is appreciated.
Old 10-22-2013, 09:22 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
sorry to hear that bud!
first off welcome to the forum.
the issue might be hard to pin point at first. water + electrical things = nightmares the never end.
a guy on here in a 4th gen took his ram swimming and has been fighting electrical issues for months. every time he fixes something, something else breaks. bad TCM, bad fuel pump, etc.
I've always heard if you get it wet, pull it out and DON'T start it until it's dry. But you are well past that point. hopefully some more mechanical minded people will chime in to help you diagnose. good luck man :/
Old 10-22-2013, 09:27 AM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
It also could be as simple as flushing all your fluids. If your breather hoses on the tranny and axles aren't high enough out of water, these parts could have taken water in. Just another thought.
Old 10-22-2013, 09:29 AM
Rep:1900
^^^^^^^^^^^^^^ yes for sure.
to clarify, i wasn't trying to say it is DEFINITELY an electrical issue. I just meant to prepare for the worst is all.
Old 10-22-2013, 09:39 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Check your air box for water. A wet filter could be the problem.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-22-2013, 11:09 AM
I checked the air intake for water, it was dry. I will definitely need to check the tranny and axles for water. thanks for the help.
Old 10-25-2013, 06:04 PM
alright, checked the transmission fluid and it had water in it. Am I screwed and ruined my transmission or is it possible to flush the contaminated fluid out and be alright? I heard both not sure who to believe.
Old 10-25-2013, 06:16 PM
Butter's Avatar
Butter Butter is offline
Vehicle: 2010 Ram 1500 4x4 RC/SB
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
I would change the oil and filter and see what happens.
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 10-26-2013, 08:00 AM
gcscott's Avatar
Rep:1043
If your transmission has water in it, you need to change the fluid and I would also look to see if you have a drain plug on the torque converter. You need to get all the fluid that you can out of the transmission.
Old 10-26-2013, 09:20 AM
jeepfan93 jeepfan93 is offline
Vehicle: 1997 ram1500 club cab
jeepfan93 is on a distinguished road
For sure on the trans. I do alot of wheeling and end up in deep stuff all the time. Flush the trans. The vent is kind of low on the trucks and sucks water in. When you're done with that, check the diffs and T-case. Also pull your rear brake drums and flush them with brake clean. If you're gonna wheel it, this is your new process after wheeling to ensure a long service life out of your parts.
