Old 10-20-2013, 05:08 PM
Ribsey80 Ribsey80 is offline
Vehicle: 2011 dodge ram 1500
Ribsey80 is on a distinguished road
Default HID lows shut off when engine started. Help!
Hey, I have a 2011 ram 1500 with the quad headlights. I just installed ddm hid kits on the fogs and low beams. No problem with the fogs but the lows flicker for a sec and then shut of when the engine is started. ( they stay on fine when engine is off ) I ordered a pair of error eliminators from DDM after reading that I will need them for the quad headlight system but haven't received them yet. Will these fix the issue or will I need to add resistors or capacitors some where in the system?
Old 10-20-2013, 10:11 PM
Also, I have found that these kits are making my Tire Pressure Monitoring System go crazy. I removed the low beam kit for now until I can find the solution but left the fog kit on. When I turn on the fogs, they work great but the TPMS light comes on for a few seconds? Do I need error eliminators for that kit as well?
Old 10-21-2013, 10:20 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I put a 35 watt DDM kit in my fog lights and had to use a wiring harness from DDM to get the fog light ballasts to work. I didn't need any error eliminators. I had no problems with the TPMS light.
I haven't decided which low beam kit, but I am looking.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-21-2013, 10:30 AM
Asur Asur is offline
Vehicle: .
Rep:4364
Get a wire harness with the resistors and capacitor it will solve your issues
The TPMS Sensor is located near the Fog light area, when the ballast triggers the Plasma ball it produces enough electromagnetic interference to screw with the TPMS Sensor, once the Triggering of the HID bulbs is finished the interference stops, no worries, known issue.
