Old 10-19-2013, 06:55 PM
tubthumpr tubthumpr is offline
Vehicle: 2010 dodge Ram
tubthumpr is on a distinguished road
Red face Can Bus led from Autozone
OK here we go, I have a 1999 Dodge Ram Laramie 4x4, and am in the process of switching to leds. I bought a electronic turn signal relay and installed Can Bus Leds from autozone in my tail lights. Now for some reason when I hit my brakes my dash lights come on. My brother bought some leds off of ebay and I tried them and they work fine, perfect flash and brakes, and no dash light or tag lights come on when i hit brakes or turn signals. Has anyone else had this problems and if so what kind of led do i need to look out for as not to buy.
I bought some off of ebay and but in front and they work fine, is can bus a typed that i need to be aware of. Tanks in advance for any help.
Old 10-19-2013, 06:58 PM
Jhouse's Avatar
Jhouse Jhouse is offline
Vehicle: 2014 ram
Color: blue streak pearl
Rep:163
Jhouse has a spectacular aura aboutJhouse has a spectacular aura about
I had a similiar problem. I bought some at pepboys and when i hit the brakes my front markers and license plate lights lit up too. I added resistors and then it showed bulb out on my dash
K&n cai, bt catch can,moes 87mm throttle body,flowmaster super 44,20% tint front 15% rear,egr vent guards, black weatherguard toolbox, debadged,tinted tails,retroshop hid's 6000k in fogs and lows, custom mopar badges
Old 10-25-2013, 09:39 PM
wells thanks dude did you finally get it fixed?
Old 10-25-2013, 09:43 PM
Jhouse's Avatar
Vehicle: 2014 ram
Rep:163
I added 13 led tail lights instead and the resistors worked fine. The bulbs must have been junk
Old 10-27-2013, 10:15 PM
buddyleewv buddyleewv is offline
Vehicle: 2012 Dodge Ram Quad Cab
Trim Level: Tradesman
Color: True blue
Rep:30
buddyleewv is on a distinguished road
I bought cheap LEDs when I first put them in my truck and when I hit my break my fronts turns would come on with or without resistors. I found out you get what you pay for I bought better LEDs from super brights and have had no problems
Old 11-16-2013, 08:09 PM
ok heres a update, I found out that the Can Bus led you get at Autozone are for trucks and cars with the can bus system and not regual led bulbs. I bought some leds form superbrights and they work perfect after i put a electronic turn signal relay in.
led, led brake lights, led tail lights
