Old 10-18-2013, 12:02 PM
hypoxia hypoxia is offline
Vehicle: 2014 Ram 1500
Rep:87
hypoxia will become famous soon enough
Default Recreational Towing with 8 Speed
Can someone with an 8 speed 4X4 try to put their transfer case into and out of neutral following the manual?
In the Owners manual page 603 Item 5 "Turn Engine Off. On 8 speed transmissions the shifter will automatically select park when engine is turned off".
My engine will NOT turn off unless I select park first. I sent customer assistance an email asking about that and received an answer that did not address the question.
I have towed it 700 miles & it's a great toad.
Old 10-18-2013, 07:33 PM
KnuckleHead's Avatar
KnuckleHead KnuckleHead is offline
Color: Black/Silver Two Tone
Rep:89
KnuckleHead will become famous soon enough
Mine is the same. You cant turn if off unless it is in Park.
2014 RAM 1500 Laramie...Ordered 8/3/13, Built 9/10/13, Arrived 10/1/13.
Old 10-18-2013, 08:04 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:528
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
That's weird. The 2 times I forgot to shift into park before turning the key off, the truck shifted and the park indicator blinked after the truck turned off. I started it up to be sure and it was indeed in park.
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 awaiting installation.
Old 10-22-2013, 10:45 AM
Rep:87
Received a call from Ram engineering. Said the owners manual was in error and that you have to put it in park manually. Also noted that the online manual is different than the large printed manual.
