Old 10-18-2013, 12:32 AM
Kuzikan2010 Kuzikan2010 is offline
Vehicle: 2010 Dodge Ram SLT
Rep:128
Kuzikan2010 will become famous soon enoughKuzikan2010 will become famous soon enough
Default Fitting 22x14's...HELP
I own a 2010 Dodge SLT 4x4. I'm looking to see what it would take to fit 22x14 w/ -76 offset on Toyo Open Country M/T's 37x13.50/22. Right now I plan on getting the BDS 6'' kit w/ a Zone 1.5'' body lift, would that be enough to properly clear the x14's? I know they are wide so clearing them is essential. Would I need more than just 7.5''(6'' BDS + 1.5" Zone) to clear them?
2nd question
Will the M/T's 37x13.50x22's actually fit on the x14's? I don't want the ballooned look on the tires, if they are stretched what would fit better? I'm not really a tire guru.
Thanks
2010 Dodge Ram 1500 SLT Quad Cab 4x4
Old 10-18-2013, 01:11 AM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
The tire will fit the rim. It will look like this..
Simon
Old 10-18-2013, 01:37 AM
LowUFO's Avatar
Rep:1105
In terms of clearance, you'll have an inch and a quarter more than stock 20x9 rims w stock 275/60/20 tires on the inside. The new tires will sit about six inches further out on the outside.
The new tire circumference is 4" bigger than stock 275/60/20. Only half of that is above the hub. So you'll clear w that lift nicely.
Simon
Old 10-18-2013, 01:41 AM
LowUFO's Avatar
Rep:1105
But make sure you have the gear ratio to push those tires. If, like me, you're running 3.55 gear ratio, the most you'll want to run is a 35" tire. Here's to hoping you have 3.92 gears.
Simon
Old 10-18-2013, 09:03 AM
Rep:128
LowUFO,
Thanks for the help. I tried doing all the conversions in my head and well, that's why I posted on here. Thanks a lot! That wheel doesn't look too bad, kinda wanted a more square/flush look but that's not bad at all.
Old 10-18-2013, 09:55 AM
LowUFO's Avatar
Rep:1105
Then maybe look at a 22 x 10 or 22 x 12 rim. Then the tire won't be as stretched and it will square off better.
Simon
Old 10-19-2013, 05:29 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Generally I do not recommend running a wheel that is wider than the tire, most who run 13.50's will run a 10" wide or 12" wide wheel, if you are looking into a 22x14 I would be much more comfortable advising you to run a 15.50" wide tire, with that said you are going to for sure need to go up a little higher or do some trimming to have clearance at full lock, a 13.50 you should have no issues with the lift you are wanting to do.
If you have not yet decided where you are buying your wheels/tires/lift reach out to us we have some of the best discounts for our fellow forum members, and some very steep discounts on BDS you will not find a shop selling it for less. We can have everything delivered to your door all you have to do is have it put on, and our wheels and tires come mounted/balances/ w/TPMS installed if you need them so all you have to do is take your old ones off and put the new ones on
Let us know how you come out and once you get it all done be sure to post up some pics
Thanks
Jeremiah
Old 10-19-2013, 05:32 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
those are some pricey wheels right their, just quoted a guy for some American Force Bravo's at almost over 1k per wheel, they are very nice, but very pricey too, the quality is top notch though, and you do not see them every day so they are eye catchers for sure!
Old 10-19-2013, 06:01 PM
shawnu's Avatar
shawnu shawnu is offline
Vehicle: 2012 Ram
Rep:517
Im no help at all for the fitment part... but i can help for motivation!!
I seen a 4th gen 2500 lifted up with that stance...needless to say i had to go home and change my britches...lol
New audio build in progress
Old 10-19-2013, 06:39 PM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
those 2500's with the 20x14 -76 wheel are sexy! here is a couple pics that popped up in conversation over on the ChargerforumZ that has been going all day you can check out the thread here http://chargerforumz.com/showthread.php?t=159517&page=3
Thanks
Jeremiah
