Old 10-17-2013, 01:04 AM
BigH0ss's Avatar
BigH0ss BigH0ss is offline
Vehicle: 2013 Ram
Trim Level: Regular Cab 4x4
Color: Maximum Steel
Rep:122
Post Which Leveling Kit?
I want to level/lift my reg cab 4x4. I found a 2" and a 2.5" kit. I want to run 35's. On the flip side I don't want the front to be higher than the front like a pre runner Advise?...
Old 10-17-2013, 04:19 AM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Adjustable Bilstein 5100's hands down. They are a much better option than a spacer to level the front of a 07+ Ram. They will lessen the risk of damaging front end parts because of their design.
To figure out exactly how much front end lift you need to be level you need to measure your truck as it sits now. Put it on flat ground and measure all 4 fender heights. From there you can determine your rake and do the math to figure out how much lift you need on the front. You'll want to retain at least 0.5" of rake to avoid looking nose high.
