Old 12-06-2013, 02:41 PM
Monster5601 Monster5601 is offline
Vehicle: 2013 RAM 1500 Laramie
Color: Cherry Red
Rep:465
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Originally Posted by truman0501 View Post
Asur,
It seems that you have a lot of great info on HID's and HID installs. I've done searches but haven't found anything solid. I was wondering if you have a link to any of the "retro" company installs or if there is a place that I could find videos or etc. I'm just trying to get all the info I can find!
Thanks in advance!
There are threads here that discuss HIDs in the RAMs with projector lights buried in the time-line. It is not a big deal to install and like Asur mentioned go with the retro solution. Here is an on the road picture (from my dash camera) in the early morning hours. I'm running 4300K 55 watt HIDs from retro.
Old 03-14-2014, 05:31 AM
JCMeza1982 JCMeza1982 is offline
Vehicle: 2013 RAM 1500 Sport 4x4
Color: Mineral gray
JCMeza1982 is on a distinguished road
Here's what I just ordered: Retro Solution's
55W DIGITAL HID KIT for Head Lamps
Bulb Fitment:9012/HIR2 (+$2)
Bulb Color:6000k cool white
Vehicle Applicationodge RAM 2013+ (+$31)
Ballast Type:Regular (all in one)
Bulb Capping?:No Thanks
Hopefully it's a straight forward install. I had issues with DDMTuning's HID kit.
I have the 2013 RAM Sport QC w/proj
Old 03-14-2014, 10:31 AM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
Some people still like Retro Solution's, others have actually strayed away due to lack of customer service now. Let us know how the kit goes for you. That is the correct sizing and everything so I think it's wether the harness has everything or not. What happened with the DDM kit?
Old 03-14-2014, 06:52 PM
firefighter830 firefighter830 is offline
Vehicle: 2013 Ram 1500 Sport
firefighter830 is on a distinguished road
I've been leaning towards RetroShop 55w 600k for the headlights and 35w 6000k for the fog lights, but haven't pulled the trigger yet....
Old 03-19-2014, 03:56 AM
Color: Mineral gray
Default wiring harness
Did you use the HID wiring harness that it came with? I'm curious where you mounted and grounded everything?
Old 03-19-2014, 04:13 AM
Color: Mineral gray
I hope I don't mess up my whatever sensors by not installing the HID wiring harness... FML I hate all this custom modifying crap. (jk, only the electrical part.)
Anyone in Sacramento that can help me?
Old 03-19-2014, 05:57 AM
Color: Cherry Red
Rep:465
Yes, it is a good idea to use a relay harness. If you do not use a relay, your HIDs will likely flicker because of the way the headlamps are powered by the factory harness (PWM). The relay can handle the short off voltages in the modulated power cycle (see the scope shot of the headlamp power feed) and not unlatch preventing flicker.
You also need load resistors to keep the current pull high enough to make the BCM think they halogen bulb is there and functional. Despite popular believe, a HID ballast pulls about half the current the halogen bulb uses.
I ran a ground wire from each ballast mount point to the battery.
http://www.ramforumz.com/PHOTOPOST/d...um/pwm_RAM.JPG
Old 03-19-2014, 01:29 PM
Color: Mineral gray
Default @Monster5601
Thanks for the quick reply!!
Old 03-19-2014, 11:46 PM
Color: Mineral gray
@Monster5601
You mentioned you ran the ground wire to the battery. Were you able to remove the nut from the negative bolt? I tried removing it so I can slip the O ring but the nut stops at the end of the bolt. Also in the HID wire harness is there one plug that doesn't get connected?
I tried following the instructions but I'm better off with a visual perspective of how things get connected. excuse the ignorance. It's obvious I'm not good with this sort of stuff.
Old 03-20-2014, 05:42 AM
Color: Cherry Red
Rep:465
@Monster5601
If memory servers me, there is a mechanical connection point on both the positive and negitive battery terminals, this is were I made my connections. I do not recall an issue of getting the nut off so I could slip the o-ring over the threaded stud.
On the passenger side of the harness there will be a connector that doe not connect to anything, this is normal. It is just the way the cable was made using standard parts.
No need to apologize, we all have our areas of strengths and weaknesses but none of us are ignorant. Success is understanding your weakness and seeking help
