Old 10-16-2013, 02:56 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
well thats just stupid lol disregard my comments then
Old 10-16-2013, 10:28 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Tell me about it....I found out the hard way! The day I installed my HID's in my 13 I couldn't get the fogs to fire for love nor money. I finally got my son to switch the lights on and off while I watched what was happening. Sure enough they would fire, start to flicker then shutdown. Threw in antiflicker module...boom fog lights.
Big Red my old 2011 Sport
Old 10-25-2013, 02:39 PM
TheeDodgeFather TheeDodgeFather is offline
TheeDodgeFather is on a distinguished road
So I finally received my relay today and shortly after installing I ran into another problem. The fogs run great when the truck is off but as soon as I fire her up they flicker again? so is my only other option to buy the canbus ballasts then ? Thanks again for your help guys.
Old 10-25-2013, 03:59 PM
Asur Asur is offline
Vehicle: .
Rep:4371
If you still have issues contact sales at retrosolutions or theretrofitsource or retroshop and ask them for the wire harness that will work with your truck, it should have resistors, relay and capacitor.
Old 10-26-2013, 08:54 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I have DDM 35 watt HID's in my fog lights and only needed a wiring harness to get the lights working in my 2013.
The wiring harness I have goes from the battery to the relay then to both HID ballasts. The factory fog light wiring on both sides goes to the relay to trigger the relay.
The part that you got does it connect directly to the battery?
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-26-2013, 02:53 PM
Yes it connects directly to the battery. I had to install a harness in order to get my hi's to work, its the exact same harness. Its weird because it works fine when the truck is off but as soon as I turn it on they flicker.
fog light, help with lights, hid
