Old 10-14-2013, 08:16 PM
TheeDodgeFather TheeDodgeFather is offline
TheeDodgeFather is on a distinguished road
Default HID fog light flickering help!
Hey guys I just installed hi and lows without having much too much of an issue. I tried installing the fogs which I thought was pretty straight forward and nothing but problems. First I plugged everything in and the left worked perfect but the right started flickering so I figured maybe it was the ballast or the bulb so I switched everything around to test it and the ballast and bulb worked on opposite sides so it is not the bulb or ballast that doesn't work. I tried turning the truck on to see if anything would change and now both fog lights flicker. I know they are plugged in correctly and I have tried reversing polarity with no luck, my guess is its not getting enough power to run both. I really have no clue about HIDs as this is my first time ever installing these. If anyone has any ideas please let me know. This is driving me nuts!
Old 10-14-2013, 10:04 PM
moparornocar72's Avatar
Rep:630
Post a picture of what ballasts etc you are using!
14.268 @ 95 MPH Full Trim
Old 10-14-2013, 10:43 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
You need a wiring harness for the HID fog lights. The factory wiring does not have enough power to run the ballasts and that is why your lights flicker.
To test the HID lights attach the ballast directly to the battery and you will not get any flicker.
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-14-2013, 11:09 PM
I ordered them from Absolutehid.ca not sure what kind they are
I emailed the owner he said I need a canbus ballast or a relay? Hopefully I can exchange ballasts that seems much easier then using a wiring harness.
Old 10-15-2013, 10:02 AM
gcscott's Avatar
Rep:1043
A wiring harness is a simple install and will keep you from killing your TIPM module. The cost is $10-15 and come with 1-2 relays and are plug & play.
See post http://www.ramforumz.com/showthread.php?t=155202 Read the first 2 posts with good information.
Greg
Old 10-16-2013, 12:11 AM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
A canbus ballast will work, or you can also install an antiflicker module. I'm running canbus ballasts on my fogs without any issues. Antiflicker modules are inexpensive, check with any of the truck outfitters in your neighborhood that carry lighting.
Big Red my old 2011 Sport
Old 10-16-2013, 12:46 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
You should not need a harness for the fogs they are plug and play but you need a harness for the high and low hid
Old 10-16-2013, 12:50 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
I have had hids in my low and fogs for 3 years you wont fry your TIPM module thats just a dealer being a dusche dealers dont like mods wont you install them and the harness the tpms light will come on for a few secs thats normal but any his place will sell you the harness
Old 10-16-2013, 12:51 AM
dodgert's Avatar
Trim Level: rt
Rep:1061
No you need the realay aka harness but its simple to put in
Old 10-16-2013, 01:11 AM
Stump3r's Avatar
Rep:1266
The 13's they updated the fogs and they are now routed through the canbus loop So it's a canbus ballast, anti flicker modules or a relay harness.
fog light, help with lights, hid
