Old 10-14-2013, 12:20 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
Default Set up picture request
Was wondering if anyone with a 3rd gen truck can show there HID set up on where the mourning ballast, wire harness, capacitors, etc. need to install mine and would like to see hat others have done!
Old 10-14-2013, 02:51 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I know it's kind of cheezy, but it worked well for me and continues to work well for me. I just put all the extra wiring and ballasts in the cubby of the bumper. It was way easier than trying to mount it to the frame. I haven't had any issues from doing it that way. Maybe one day I'll get some motivation to do it, but then again, one day I'll hit the lottery, too.
Old 10-16-2013, 10:36 AM
Rep:25
I'll have to check that out, but anyone else? I know you guys have HIDs little help is appreciated!
Old 10-16-2013, 10:58 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I don't know if this helps as I have a 4th. gen. truck. I used 3M double sided tape and tie wrap to hold the ballast to the frame rail. So far nothing has moved.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-16-2013, 11:12 AM
Kamanhart's Avatar
Kamanhart Kamanhart is offline
Man Up And Cam Up
Vehicle: 2005 Dodge Ram 1500
Rep:1045
Kamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud ofKamanhart has much to be proud of
I mounted my relays and ballasts to the core support rails on my 05, im at work right now but i will grab some pictures when i get off and post them
Old 10-16-2013, 05:40 PM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Just got off work here is how i set mine just just really for convenience and easy access
This is the drivers side, the top relay is not part of the HID kit it is for my led rings behind my projector housings. the ballast is the one on the inside and the relay is on the outermost side, i used some self tapping screws and in turn just used that as my ground point as well.
Passenger side
Old 10-16-2013, 08:13 PM
Rep:25
Thanks guys!
Kamanhart did you use self tapping screws?
Old 10-16-2013, 10:15 PM
Kamanhart's Avatar
Man Up And Cam Up
Rep:1045
Yes sir I did 1/4 inch I believe I did go ahead and drill a pilot hole first just to make the self tapper go in easier im really happy so far. I had a ballast go out on me and retro solutions had me test all my grounds to make sure it wasnt operator error and they said my resistance readings through my grounds were some of the best they had seen so it seems to be working really well
Old 10-18-2013, 02:48 AM
Canadian Hemi Pride's Avatar
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2793
Well I don't have caps.. Just the HID setup with a relay harness.. Can honestly say that it is a extremely ghetto set up.. I think my driver side balast is hanging off my aftermarket alarm horn with zip ties... I used a lot of zip ties for my kit.. Way to many.. And electrical tape.
Tow mirrors up for the haters
Old 10-18-2013, 10:07 AM
God Bless Texas!
Rep:2929
You can never have or use too many zip ties.
