Old 10-11-2013, 06:53 PM
av41medic's Avatar
av41medic av41medic is offline
Vehicle: 2013 Ram Sport 4X4 CC
Color: Deep Cherry Red
Rep:16
av41medic is on a distinguished road
Default Always on fogs '13?
Hey guys, I'm almost positive this has been questioned before, but i've been searching for the last half hour with no success. So, is there a relatively easy way of having the fogs activated on a full time basis?
Old 10-11-2013, 07:04 PM
Grubrunner's Avatar
Rep:3883
Yes.
Turn the light knob to the park light position and press the switch to activate the fogs.
That is what you meant, right?
Are you running them as DTRL or you have something else in mind?
Grub out!
Old 10-11-2013, 08:11 PM
av41medic's Avatar
Rep:16
Ya, I just want them to come on with ignition. My LED's are already DTRL, I wanted the fogs as well. It would be nice not to have to use the HL switch every time.
Old 10-11-2013, 10:05 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
As far as I know, if you want the fog lights to come on you have to have the parking lights on.
The only way to get around this is to install HID lights in your fog lights and then take the wiring harness (from the HID lights) using the trip wire from the relay and attach it to a switched circuit that comes on when you start the truck. Not to hard to do.
This will get the fog lights on all the time. Use 35 watt HID lights and a wiring harness nothing else is needed.
I have HID fog lights, but I just turn on the parking lights each time. Also with the parking lights on you get the tail lights which is safer. Light at both ends. JMO.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 10-14-2013, 02:20 PM
av41medic's Avatar
Rep:16
Thanks for the suggestions. Reading you post got me thinking, couldnt I just use a relay with the existing setup?
