Old 10-08-2013, 10:54 PM
CavemanX's Avatar
CavemanX CavemanX is offline
Vehicle: 1994 Dodge Ram
CavemanX is on a distinguished road
Default 1994 Ram 1500 Performance
I recently got my first truck, a 1992 Dodge Ram 1500 with the 5.2, and was wondering what mods I can do to it to get better gas mileage. I wanted to put a performance chip in it, but noticed the thing has no OBD connector. Is there still a way I can put one on?
Old 10-13-2013, 10:14 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
The early MAGs were pretty much limited to the Mopar Performance ECM. Seems like Jet offered something back then, but things didn't really open up til the OBD II systems. You do have the best of the Magnum OEM exhaust systems. They're bigger internally at 2 1/8", while all later units are 1 7/8" internally. Bigger passages, better flow, more HP.
Old 10-19-2013, 01:50 AM
CavemanX's Avatar
I just realized. I said 1992. I have a 1994. Oops...
Old 10-19-2013, 03:54 PM
quadcabman2001's Avatar
quadcabman2001 quadcabman2001 is offline
Vehicle: 2001 ram 1500 quad cab
Trim Level: quad cab
quadcabman2001 is on a distinguished road
There are plenty of things you can do for your 94
Old 10-21-2013, 12:15 AM
CavemanX's Avatar
Like what, though? I'm wanting a performance and mpg increase.
Old 10-21-2013, 01:23 PM
Rep:85
Cam, heads, intake manifold, exhaust. All the traditional stuff. You just have to tailor your choices with the computer in mind.
Old 10-27-2013, 01:38 PM
cdetterer's Avatar
cdetterer cdetterer is offline
Vehicle: 1996 Dodge Ram 1500
Trim Level: Laramie SLT
Rep:42
cdetterer is on a distinguished road
I think you are pretty limited with the "bolt on" instant gratification "plug n play" additions. How many Miles are on your truck, What kind of miles are you pulling? Auto or manual?
Here are some of the easy not highly mechanical you can do things to do:
And don't skimp if you actually want results, Like a good Mobil 1 or Royal purple synthetic oil. and good spark items.
E3 Diamond Fire Plugs
MSD Cap and Rotor
MSD Coil & Adapter
MSD Plug Wires
New Tensioner Pully
New Serpintine Belt
Synthetic 0W30 Oil Change with High quality filter( I recommend Royal P, gets finer impurities)
Synthetic Diff Oil Change
Synthetic Transfercase Oil Change
Synthetic Tranny Oil Change, if automatic a good filter
Add Lucas oil stabilizer to all oiling systems
Flush cooling system
Proper Tire Pressure
Remove ALL unwanted Lbs
Cold Air Intake
Run Lucas injector cleaner with gas (double up first tank, then the 3oz per 10gal the rest of the bottle)
Take the throttle body off and clean it so its not all gunked up.
If you want to do a little more and dont want to rip into the engine to far
Add a lighter fan, or ditch the mechanical and go to an electric mounted on the radiator
You can also do a few mods that have been discussed on here( just search them):
The ball pen throttle cable mod
The intake wing shave mod
The Kegger mod.
For the better of your future while your intake is off, invest in a Hughes Plenum Kit. Will make your life easer, you wont have to spend as much money on plenum gaskets and burnt up oil.
Old 10-27-2013, 01:47 PM
cdetterer's Avatar
Rep:42
Also Congradulations on getting a truck!
I forgot a couple other things to pertain to 4x4
If your running 35"+ tires, you might want to look into gearing up to like a 4.10 in you diffs
Another addition would be a Posi-Lok system if your really into four wheeling or are wanting to make it a weekend wheeler. You wont have to rely on the vacuum to engage your 4x4. Also this gives you a low gear in your rear, Helps with like towing or rearend "diggs"
Also check this out its a pretty sweet episode that was one quite a few years ago:
http://www.powerblocktv.com/episodes...tart-to-finish
If you need help with anything else, just jump on here there are plenty of guys willing to help you out. and dont be afraid to ask even if it seems like a dumb question, ask it you will become smarter.
Old 11-02-2013, 12:34 AM
CavemanX's Avatar
Thanks cdetterer! I'm already getting a cold air intake, and was thinking about electric fans, and cleaning up my throttle body. Although, some electric fans are quite expensive. Does anyone know of a cheap setup to buy, or what all I should buy? Big newbie, and want to gain some knowledge.
Old 11-05-2013, 01:56 PM
cdetterer's Avatar
Rep:42
Check out Summit Racing or Jegs They have some good kits that have the mounting hardware and wiring. Most of them are pretty reasonable, like $100-$150.
Best thing I can say for gaining knowledge is research. You know read what you can. Then when you have repairs to do, look up how to do them yourself. It also saves some money. But be sure you know how to the project start to finish before you start taking stuff apart.
You can always ask questions on here, I know I have felt like I have some really no brainer questions and all the guys on here are extremely helpful, so dont be afraid to ask.
1994, mpg, performance
