Old 10-08-2013, 01:20 PM
Rogerwa's Avatar
Rogerwa Rogerwa is offline
Vehicle: 2009 Dodge Ram 1500 5.7l Crew
Color: Greystone
Rep:30
Rogerwa is on a distinguished road
OK, so they map lights now fade correctly. they just fixed themsleves. They work as map lights only when the key is turned on. I am guessing that this is the resistor issue and that the TIPM tries to sense whenther the light is on or off so it knows when to cut power in the event someone leaves one on. I will try to see if the resistor corrects the problem.
Also, with the rear dome light (crew cab), it strobes. Resistor is the first step here as well.
The color I chose was the cool white. I am rethinking that as it seems a bit sterile. I am going to try the natural white and see if that helps.
I have both the 4 LED and 12 LED models for the map lights. The 12 is OK, but just a bit much. I am thinking the 6 might be better.
2009 Ram 1500 Big Horn Crew Cab 5.7l Hemi
Twin Cities, MN
Old 10-08-2013, 01:30 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Let us know how it turns out.
