Old 10-03-2013, 06:05 PM
1999ram318 1999ram318 is offline
Vehicle: 1999 Dodge Ram
Color: Forrest Green
1999ram318 is on a distinguished road
Default Tranny Fluid Change or Flush?
My truck has 142,xxx on it. Its a 99 ram with a auto transmission. The fluid doesnt look the best and the tranny overheated on me a week ago. Planning on flushing the tranny this weekend but ive heard flushing can loosen old stuff and create more problems. Any suggestions or tips? Thanks
Old 10-03-2013, 07:24 PM
Grubrunner's Avatar
Rep:3883
I've always been told a flush is the way to go.
Some say while it does remove all the old fluid, it induces present dirt into delicate areas thru the flush process.
A change does not pull all the old, existing fluid so it's only a partial replenishment.
A flush with zero chemical additives is my preferred method.
Grub out!
Old 10-03-2013, 07:26 PM
Grubrunner's Avatar
Rep:3883
Oh, are you having any slippage?
Grub out!
Old 10-03-2013, 07:46 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
That's what I was going to ask. If you're having shifting problems or slipping...you'd be amazed at how many transmissions come into a scrap yard with crystal clear fluid and the trans is shot.
It usually happens when someone is experiencing problems and has a flush, service, and filter. Then it gets worse and they scrap the vehicle because in their opinion it's too much expense to put in a new/rebuilt trans than the vehicle is worth.
So...if you're having problems with the truck I'd stay away from the flush.
Just my opinion.
Old 10-03-2013, 07:53 PM
Arth's Avatar
Arth Arth is online now
Color: Mineral Gray Metallic
Rep:2028
This is my personal opinion on this but if you overhead anything then it is only a matter of time before you will need to replace it.
I push this thought even further for transmission because they operate with frictions and clutch packs.
Chrome... in moderation.
Old 10-07-2013, 02:53 PM
beginningjockey's Avatar
beginningjockey beginningjockey is offline
Vehicle: 1996 Dodge Ram F1500HD Custom
Trim Level: SLT Laramie Custom
Rep:22
beginningjockey is on a distinguished road
Flushing it the way the fluid is supposed to flow is a good way to clean the trans, but IMO if you change the fluid and filter and use premium fluid at 15K you will never need a flush...
Most flushes run backwards through the system, so they can be harmful in putting stuff where it isn't supposed to go.
for me I just used to change it frequently with good stuff and never needed a flush.
1996 Dodge Ram F1500HD Custom, 5.2L 318 V8 4BBL NV4500HD too much more to list! *FOR SALE*
Old 10-07-2013, 03:27 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Rep:326
I wouldn't flush it. These transmissions are pretty weak and prone to go out anyway. You don't want to disturb them too much by getting debris/clutch material in places where they weren't before.
Just do a fluid and filter change.
Old 10-07-2013, 05:18 PM
Hermes1's Avatar
Hermes1 Hermes1 is offline
Vehicle: 2012 Ram 1500 Sport
Color: Flame red
Rep:2554
Curious to know, do you also change the filters at that interval?
Best, Bruce
Sure you can take my truck, the keys are under my Akita.
Old 10-07-2013, 07:12 PM
Rep:22
at every 15,000 miles or every 3 engine oil changes (whichever comes first) on every automatic I own I change the fluid and filter, and if applicable adjust the bands/cables/position sensor.
Only after I burned out a transmission did I learn about that. I changed fluid at every 25,000 miles approx.
Put it this way:
One of my friends has a Ford 1 ton truck, he's changed the fluid and filter and adjusted the manual lever position sensor every 15,000 miles.
It's a entirely stock transmision, never been flushed, it has over 1.5 million miles on it, never been rebuilt, still doesn't need it.
He tows heavy loads regularly with it, and it's his daily driver.
He has no reason to lie about it either.
The same goes for the Dodge transmissions, Chevy transmissions, any automatic. Keep it cool and give it plenty of clean fluid, and it'll last forever (almost lol).
People complain about these Dodge transmissions failing all the time. While they could have been built better, both me and many other transmission shops noticed one thing: Changing the fluid at the factory recommended interval is usually NOT frequent enough to keep the fluid clean. Even if that fluid smells fine and looks fine, it's got lots of stuff in it you need to get rid of, and the chemicals in the fluid don't last forever either. Electronically controlled trannys depend alot more on the chemicals in the fluid than most people realize.
That stuff causes sensors on our electronically controlled transmissions to read improperly, and it also clogs/limits the proper operation of the governor. Essentially this causes the transmission to run out of spec and causes excess slipping and poor operation which adds more deposits and builds up heat leading to premature failure.
Then it's only a matter of time til it will fail...
Any rate I don't want to derail this thread...
Old 10-07-2013, 08:21 PM
Rep:2620
if you do a Flush on an older transmission
little bits of debris & dirt can get into the Valve body
in the valve body, there are ports, the ports have either a ball bearing or cylinder with a spring that holds that in place while in certain gears & allow them to open when in other gears. If dirt gets into the ports, then the ball bearing can't close the port correctly & you get strange shifting operations
fluid, flush, overheating, tranny, transmission
