Old 10-04-2013, 08:36 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Originally Posted by Thebestestdrummer View Post
haha do you have and random advice? I know i need to get a cheap special tool to take off the fuel rail or something like that though.
And yeah.. you're just a bit away! but hey! my parents are going to Texas in about 2 weeks! haha
No need to take off the fuel rail, or throttle body. Just relieve the fuel pressure with the shrader valve on the driver's side port on the fuel rail and use a fuel line disconnect tool.
Tell em to bring down the truck haha.
My advice would be to make sure the gaskets are in place and don't get moved around when you are putting the intake plenum back on. Also, use RTV on the front and rear intake manifold gaskets. Since you're going to have the intake manifold off, it would be a good time to replace your distributor cap and rotor, as well as the spark plugs and wires.
Also, the crankshaft position sensor wire on mine liked to fall back behind the distributor and it's hard to find. Just keep an eye out for that.
Old 10-04-2013, 11:37 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
it says invalid URL
Green Interior LEDs
Old 11-25-2013, 05:16 PM
Rep:326
You ever get this done?
Old 11-25-2013, 10:27 PM
Rep:529
ahhh no. This will have to be a project in the summer due to lack of money and surplus of cold weather and snow with no indoor place to tear apart my truck. I do plan on doing this though sometime when it starts to warm up again. In the meantime I migghttt take it in to a shop and have them simply replace the gasket when I get new tires or something like that where it'll already be in a shop. All depends on that terrible money factor though..
Green Interior LEDs
Old 11-25-2013, 11:36 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
If you have them take it apart, you may as well have them fix it right the first time. No sense in tearing it apart twice.
Old 11-26-2013, 12:12 AM
Rep:529
that is actually a terribly good point...
Green Interior LEDs
Old 11-26-2013, 09:39 PM
Rep:326
It's easy enough to do yourself and save some $$. Just don't rush and you'll be fine.
Old 10-23-2014, 02:13 PM
SDave SDave is offline
Vehicle: 1994 Dodge Dakota
SDave is on a distinguished road
Don't replace the paper gasket with another paper gasket. Just use a good bead of high temp silicone and it will never leak again. That is all you need. The gaskets between the heads and the intake are premium gaskets and you will not normally tear them or mess them up at all. Use clear silicone for the front and back gaskets. I have had my intake off multiple times to mod it for one. Cut the runners down you know and have never used replacement intake gaskets. I bought some the first time I pulled the intake. But when I saw the quality and the condition of the intake gaskets I just cleaned them off and left them alone where they were.
So you need a tube of high temp silicone and a tube of clear silicone and you are ready to repair the leaking intake gasket.
Old 12-12-2014, 08:01 AM
The War Wagon's Avatar
The War Wagon The War Wagon is offline
Vehicle: 1992 Dodge Ramcharger
Trim Level: LE 150
Color: Black & Grey
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Rep:31
The War Wagon is on a distinguished road
Send a message via Yahoo to The War Wagon
Lightbulb
Add performance headers, cam & lifters, double roller timing chain, and a bigger throttlebody while you're at it. Since you're ALREADY into it this deep, take care of the other stuff while you're at it! That's what I'M doing to my RC this spring!
'92 Dodge Ramcharger... a work in progress...
'07 Jeep Commander... tow vehicle... :-p
Old 12-17-2014, 09:38 AM
Rep:529
Believe it or not, this had still not been done :''''D new headlights and more hids just sound more fun! Haha. In all seriousness I plan on doing it this winter or early spring. It is starting to suck down my gas mileage quite a bit.
Green Interior LEDs
5.2, fix, gasket, hughes, plenum
